Bell Housing Removal Question
Old Jan 3, 2012 | 11:54 AM
DO2G's Avatar
DO2G
Default Bell Housing Removal Question
Is there a trick to getting the bellhousing off? I have the tranny separated and all the bolts out and it won't budge....
Old Jan 3, 2012 | 12:00 PM
63split63's Avatar
63split63
It will b hanging up on the 2 dowell pins that are between the 2 lower bolts , 1 on each side . Just carefully tap in that area and it will come apart .
Bill
Old Jan 3, 2012 | 02:06 PM
birdsmith's Avatar
birdsmith
Be careful...it's very brittle cast aluminum and can crack easily. Don't ask me how I know this...
Old Jan 3, 2012 | 04:39 PM
DO2G's Avatar
DO2G
Does the starter need to be removed to take the bellhousing and flywheel off?
Old Jan 3, 2012 | 09:35 PM
birdsmith's Avatar
birdsmith
No, because the starter is bolted onto the engine block. As long as all the bolts holding the bellhousing to the block have been removed and the couple of small bolts holding the dust shield to the front face of the bellhousing have been removed as well there shouldn't be any problem getting it off. You may have to separate it from the block in a couple spots with a putty knife, and spraying some WD40 or PB in between the housing and the block might not hurt, but I would avoid smacking it with anything more brutal than a rubber mallet or dead blow hammer. No big deal really...
Old Jan 4, 2012 | 05:29 PM
jcloving's Avatar
jcloving
I just did this. Try to pry it away from the block at the top and then the bottom.
Old Jan 4, 2012 | 06:02 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Absolutely sure all the bolts are out???
To Bell Housing Removal Question
