Engine Installers
Old Jan 3, 2012 | 10:15 PM
c3sleeper's Avatar
c3sleeper
Default Engine Installers
I've selected a new motor to install in my 1981 Corvette and am looking for a reputable engine installer in Oklahoma. I've had trouble finding any reviewers on the shops here so I figured the best would be to ask the actual consumer. The following are the specs on the engine. It is constructed by the Engine Factory in Lebanon, New Jersey.
383 CHEVY 460 HORSEPOWER STREET BEAST
REPLACES ANY SMALL BLOCK CHEVY WITHOUT MODIFICATIONS
4 BOLT MAIN 1 PIECE REAR SEAL BLOCK
NEW STROKER CRANKSHAFT
PERFORMANCE CONNECTING RODS
HYPEREUTECTIC PISTONS 10 TO 1 COMPRESSION
RUNS ON PUMP GAS
SPEED PRO MOLY RINGS
CUSTOM GROUND ROLLER CAMSHAFT
DURATION @ 050- 234/238
INTAKE LIFT .539 -- EXHAUST LIFT .548
DOUBLE ROLLER TIMING SET
HEAVY DUTY TRIMETAL ENGINE BEARINGS
MELLING HIGH PRESSURE OIL PUMP #M55HP
FEL-PRO GASKETS
NEW EDELBROCK PERFORMER RPM ALUMINUM HEADS WITH 64CC CHAMBERS #60899
NEW 2.02" STAINLESS INTAKE VALVES
NEW 1.60" STAINLESS EXHAUST VALVES
HARD SEATS AND GUIDES FOR UNLEADED FUEL
SCREW IN ROCKER STUDS
1.46 VALVE SPRINGS HANDLE VALVE LIFTS TO .575
NEW HARDENED PUSHRODS, GUIDE PLATES, AND ROLLER LIFTERS
ROLLER ROCKER ARMS
NEW CHROME OIL PAN AND CHROME TIMING COVER
NEW CHROME VALVE COVERS
NEW PERFORMANCE HARMONIC BALANCER DAMPER
NEW FLEXPLATE FOR AUTOMATIC TRANSMISSION
STANDARD TRANSMISSION FLYWHEEL EXTRA $250.00
BALANCED, BLUEPRINTED, ASSEMBLED AND PAINTED
NEW AIR GAP INTAKE MANIFOLD
NEW 4 BARREL CARBURETOR 800 CFM # 1813
NEW BLUE PRINTED HEI DISTRIBUTOR WITH 53,000 VOLT COIL
NEW CHAMPION SPARK PLUGS & HEAVY DUTY IGNITION WIRES, ELECTRIC CHOKE
HEAVY DUTY WIRE LOOMS
NEW THERMOSTAT CHROME HOUSING
NEW FUEL AND WATER PUMP
NEW FUEL LINES AND FUEL FILTER
NEW DIP STICK AND TUBE, OIL FILTER HOUSING AND OIL FILTER
NEW AIR CLEANER, COMPLETE P.C.V VENTILATION SYSTEM
Old Jan 3, 2012 | 11:18 PM
tyancey00's Avatar
tyancey00
Ask the guys in your local club. They will be your best bet....
Old Jan 4, 2012 | 01:06 AM
c3sleeper's Avatar
c3sleeper
Well in a relatively isolated of 800 people car clubs aren't exactly thriving here haha
Old Jan 4, 2012 | 08:45 AM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
You'll find most here are in the 'do it yourself"-er category. Have you asked the guys who supplied the engine this question?
Old Jan 4, 2012 | 08:56 AM
hugie82's Avatar
hugie82
Do you have an address for the shop (ie rt22) I live a few towns over from Lebanon NJ. I can ask around.
Old Jan 4, 2012 | 09:31 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Replacing an engine is a job that pretty much any decent shop can do well.
Anyone in the area with a decent reputation is most likely safe.
Old Jan 4, 2012 | 03:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Rent a hoist and do it yourself.
Old Jan 4, 2012 | 11:16 PM
c3sleeper's Avatar
c3sleeper
It's just south of route 78 on Cokesbury at exit 20B
Old Jan 4, 2012 | 11:58 PM
tyancey00's Avatar
tyancey00
Where is the car?
Old Jan 5, 2012 | 12:57 AM
c3sleeper's Avatar
c3sleeper
Originally Posted by tyancey00
Where is the car?
Shed near my home. Its for the most part a weekend car but the motor mounts had to be replaced so it was out of commission for a couple of days. Im located in North Central Oklahoma.
Old Jan 5, 2012 | 11:14 PM
spdrcr29's Avatar
spdrcr29
How did you come across this place when living in OK?
Old Jan 5, 2012 | 11:23 PM
c3sleeper's Avatar
c3sleeper
While being a local machining company they are also one of the most well reviewed online sellers of turnkey engines. I've read through hundreds of reviews on them and have found very few ratings on them that were less than just outstanding with the highlights being customer service and durability of their engines.
Old Jan 6, 2012 | 01:09 PM
Tom454's Avatar
Tom454
Or even buy a hoist. They're not that expensive.
Old Jan 6, 2012 | 01:15 PM
RobbSalzmann
St. Jude Donor '12
when you own one, you suddenly have all sorts of uses for it.
Old Jan 6, 2012 | 07:26 PM
c3sleeper's Avatar
c3sleeper
I've got no issue with pulling the motor. I work on a farm and we already have a motor hoist the only issue is that 81 is the first year to have an on board computer on all models. While mechanics are my speciality electronics are not and I would like to get the car reassembled with all systems funtiOning correctly. I'd also like to not have the car not out of commission for more than a month.
Old Jan 8, 2012 | 02:26 AM
c3sleeper's Avatar
c3sleeper
Default 460 hp 1981 Vette
New plan guys. New engine comes with vacuum advance distributor installed already. The motor will be pulled when shipment notification is received on the new motor. All computer connections will be unhooked. As the car is a manual trans it makes this much simpler with the only thing needing to be done is to simply let the check engine light glow until it inevitably burns out. The engine bay will be a lot cleaner without all the wires running to the carb, intake, and thermostat! Upon removal of the engine a Centerforce clutch will be installed to handle the additional power. Any ideas whether the stock 4-speed will have any issue handling that kind of power?
To Engine Installers
