Center Grille - Moving it Forward
Old May 10, 2002 | 09:43 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Center Grille - Moving it Forward
I just pulled the front plate off my '69 to improve airflow to the radiator. Now the center grille is sitting WAY back there looking lonely.
I know several people have moved it forward by adding some brackets or something. How did you do it and do you have any pics?
Thanks!
Old May 10, 2002 | 09:53 PM
lbell101's Avatar
lbell101
Default Re: Center Grille - Moving it Forward (ddecart)
I just used some long screws and cut a few pieces of supply tube as spacers. Works really well and looks much better.
[Modified by lbell101, 1:54 AM 5/11/2002]
Old May 10, 2002 | 09:56 PM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
Default Re: Center Grille - Moving it Forward (lbell101)
Cool. Umm...what's "supply tube"?
Old May 10, 2002 | 10:16 PM
lbell101's Avatar
lbell101
It's that chrome or plastic tubing that connects your sink faucet to it's water supply. It's like 3/8"DIA. The plastic is probably better as the wall thickness is larger.
Old May 10, 2002 | 10:23 PM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
Cool. Thanks Larry.
Old May 11, 2002 | 01:02 PM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
ttt
Anyone else?
Old May 11, 2002 | 08:17 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I used 4 inch SS bolts, 1/4 inch I think. I used 2 nuts per bolt. I first inserted the bolt & washer thru the grille and then attached a bolt and screwed it on about an inch. I then inserted the bolt thru the bracket and attached using another washer and nut.
To Center Grille - Moving it Forward
