Since you're asking, on rarely driven carbureted cars, I usually go with a rear mounted Mallory 140 electric set up. Does have a regulator/gauge mounted to the engine mechanical pump block off plate. Like this set up, as can run the pump to prime a bit before starting, bump the key and you're fired up. Also a switch, to run the carb dry, when putting away. Something to consider.
Thanks for the thoughts on this guys. Vette5.5 - Since we live in AZ, the car can be driven year around - and I'm hoping there wont' be many weeks where I don't take it out at least once or twice.
I was wondering if I needed to go with an upgraded mechanical pump, but thinking it might be a waste of $$ given the application.
BK - what is the motor like if your car? Similar to what I will be running?
A stock pump is fine to over 500 hp. provided it is in good condition. The return line keeps the fuel moving back to the tank under light throttle conditions, i.e. cruising, and helps prevent vapour lock in warm to hot climates. Does it get hot in Arizona?
Hope this helps.
Regards from Down Under.
aussiejohn
I would like to keep the return line in place. The part of Arizona I live in can reach 110f in the hottest part of the summer so that is a real concern here. I will be purchasing a new pump, but wanted some feedback before I did.
Adam - My engine is a fairly mild 383. I do put quite a few quarter mile runs on it each year and the stock type replacement pump works fine Thats with winding 1st and 2nd gears (automatic) to 5,500rpm and crossing the line at about 5,200. The only fuel starvation problem I had, other than float level on my Quadrajet, was with the paper filter in the carb inlet. I removed that and put a large in line filter between the pump and carb, and no more problem.
BK - Sounds good. I will be running an Edlebrock Performer carb on a fairly mild 350 so it sounds like a stock replacement pump is good for my application. I just couldn't see the extra $$ of a performance pump being worth it for this motor.
Mikep3 - thanks for the heads up on Napa. I'll be giving them a call.
