Bee Jay's light weight master cylinder brake mod
So, the front brakes connect to the rear of the new MC, and the rear brakes connect to the front of the MC? Is this going to cause problems, or will it work just fine that way? Sorry if that sounds like a dumb question, but I have never hooked up the brakes backwards, have no idea what the consequences would be, if any.
Damn you guys are som impatient ****'s. I picked up the 2904 at lunch today and yes it will fit my hydroboost. The big 9/16' fitting is in the front, and the little fitting 1/2" is in the back. I'll bolt it in when I get home and let you all know about the lines. Stay tuned.
Bee Jay
Bee Jay
Bee Jay
Bee Jay
ARE YOU HOME YET?
Subscribed. I have been wanting to do the hydroboost mod for a while and this could be icing on the cake.
I am not interested in the Hydroboost(tm) mod, but I am interested in using the newer style MC. Is the interface between the MC and the Hydroboost(tm) different than the stock brake booster?
Wait a minute!!!! Didn't someone post earlier about using the stock cast iron MC on their Hydroboost(tm)? Is that why you guys are all exited? It makes sense that if the stock cast iron MC fits the Hydroboost(tm), and if this newer style MC also fits the Hydroboost(tm), then........WHATEVER FITS THE HYDROBOOST(tm) WILL ALSO FIT THE STOCK BRAKE BOOSTER!!!!!!!!!
Can anybody confirm if this is the case? Should I hightail it down to NAPA and beat the rush?
Oh, wait, we are still waiting for BeeJay to let us know how it works out for him, aren't we? Well, I've lived this long with a cast iron MC, I guess I can wait a little longer. Take your time, BeeJay, when you hurry is when you make mistakes! But, definitely let us know how it works out, bro.
Scott
Scott
Same here Scott, I'm not interested in Hydroboost either. And, I'm strongly considering conversion to manual brakes, but plan on dumping the cast MC either way; preferring a factory appearance over anything aftermarket. A direct fit with C3 correct bore (per application) and plenty of reservoir to compensate for severe-duty pad wear, and that doesn't require adapting (fittings, mounting or pushrod) would be a great find IMHO.
OK, OK, I'm home.
First the good news. The M2904 fits the hydroboost. Bolted right up like it grew there.
Now the bad news. Marlin was right, the stock MC has the 1/2" port in the back. Moving the 1/2" brake line to the back a couple of inches was easy smeezy. But moving the 9/16" brake line forward a few inches is impossible. It needs to be about 3-3 1/2" longer. No problem, just disconnect it at the distribution block, take it down to NAPA and have them make me a new brake line 3 1/2" longer. Also, the MC sits much higher than the stock MC. The plastic lid is right up against my screened vent. The hood closes fine and shouldn't be a problem. So the M2904 will fit either the hydroboost or the stock vacuum brake booster. The M2903 will fit only the stock vacuum brake booster. I'll have to wait until I get a new brake line before I can tell you all how the M2904 with 1.250" bore feels. But I know a very popular mod on my Porsche is to replace the 17mm bore MC with a 19mm, so maybe bigger is better.
Scotty, here is a link to my hydroboost installation. Search is your friend.
http://forums.corvetteforum.com/c3-t...-the-hype.html
Ok....So let me confirm some info. The MC that was originally gotten by Bee Jay (the 2903) will bolt up, no mods at all to a stock C3 (74) with the vacuum booster and lines/fittings and have the same braking properties as a stock MC? If so, I might need to do this soon!
Will
Will
Bee Jay, Captain Obvious wanted me to point out for viewers that some of that height relative to your hood is due to the MC's distance out from the firewall.
And, thanks for posting up. Whether I find myself on the same page with you or not, your threads are always good reading.
#33
#34
I went with a Wilwood MC. Stock bore and everything bolts up. Very easy swap and saves a few pounds.
#36
Will
Will
Bee Jay
#37
Here is the line that needs to be lengthened about 4". The end that plugs into the distro block is smaller than 9/16" or 1/2".
I took the reservoir off. Maybe I can replace this reservoir with something lower. Maybe two cylindrical reservoirs with screw on caps. The hole is 7/8" and the distance between the two reservoir bases is 3 3/4" apart.
#38
This is what a C4 master cylinder looks like. I wonder if those reservoirs would fit? Where can you buy reservoirs only?
Also, the C4 MC bore diamerter is only .875". Now I know why every time I drove a C4 Vette, it seemed to take a lot more foot pressure to brake.
#39
Cut & Shut???
Bee Jay,
Have you considered doing a "cut & shut" on the original reservoir? With a good, brake fluid resistant glue, it shouldn't look too bad, especially if the cut was just under the lid, which would make the join difficult to see with the lid on. It would more than likely still hold plenty of fluid, if the cut was only a half inch or so.
I'm planning on a Holden MC for mine, which has the pressure regulating valve built in to the MC, and the whole lot weighs only 1.1 Kg, 2.6 Kg less than the stock MC. It also has metric threads at the outlets, so I will have to make up new lines anyway to go to the stock distribution block. I will move the switch wire up to the Holden MC. I just have to work out how to disable the switch mechanism in the distribution block, or I will just use a Holden dist. block and do away with the Chev one entirely.
The Holden MC has only an inch bore, so more pedal travel, but this might make it easier to regulate the pressure applied to the calipers. If this doesn't work out, I will just replace the Corvette MC and re-use the old lines.
Any thoughts on this?
Regards from Down Under.
aussiejohn
aussiejohn
#40
Anybody know, for us early 70's c3's, if the dimple master cylinders will fit the older style boosters?
Seems the older ones have the rod stick out 1.6" while the newwer, later 70's+, have just the dimple.
