Cam Break-in ,first start timing
Bring the engine to TDC #1 compression by the timing marks. Make sure it's the compression stroke on #1 by holding your finger over the #1 plug hole and feeling the compression "burp" past your finger.
Rotate the engine back to about 12-16 BTDC by the timing marks. The engine will *not* start or run at TDC.
Align the oil pump intermediate shaft with the #5 intake pushrod using a big screwdriver. Mark the center of the #1 tower on the distributor body and drop the distributor so that the center of the rotor points directly at the mark on the distributor body. You'll have to start the rotor behind (counter-clockwise) a few inches and try a couple of times before it drops...but it'll work and things will generally line up
Ideally you've also filled the bowl of the carb with fuel so it fires right off.
Double, double check the firing order and everything else you can think of. A little time spent here can save you a lot of time later.
Finally, be sure you're using the right oil and/or oil + break-in additive.
I'm sure it'll go great - post pics
I will be priming engine and I was planning on using Edelbrock 30 w break-in oil. Is it best to change out the oil after the 20 min cam break-in or should I drive it a bit before the change .
Some might add poor metallurgy in cams/lifters, but I'm not convinced of that personally.
In the end it's about being careful and protecting an investment.
Static timing is set by first following the directions posted above to get the dist in. Now bring it around to your timing marks again and stop the crank exactly where you want your initial timing set. Connect your 12v test light clip to the - post on the coil and stick the probe on a good ground. Push the dist clockwise so that you are early. Turn the key on the test light should be out. Pull the dist toward you and stop at the moment the test light comes on. The dist has just fired #1. You are within a degree or 2 of where the timing light will put you. This is easily adequate to run at rpm for your cam breakin.
Steve g
Check the link in the engine builder mag article below reguarding hydraulic intensity
has lead to the failures you are seeing. Actually the cam cores of today are far superior to the originals in the C3. http://www.harveycrane.com/duration.htm
http://www.enginebuildermag.com/Arti...r_failure.aspx
Steve g
Snug the dizzy down, connect the wire to the coil, prime the carb and watch it fire on the first crank.
Oil is cheap insurance. I also use break in additive for the first 500 miles.
