Hardened Valve Seats
Old Jan 11, 2012 | 12:10 PM
brrujo's Avatar
brrujo
Default Hardened Valve Seats
Going to pull the heads on my 73 L48 and replace the valve seals. Don't know the condition of the valves. I have no indication that there is any problems other than worn out valve seals. Motor has never been apart w/46000 miles.
My question is if a valve job is in order, should I replace the seats with hardened ones.
Old Jan 11, 2012 | 12:15 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If I were you, I'd just replace the valve seals. You don't need to pull the heads to do it.
Old Jan 11, 2012 | 12:19 PM
Manuel Azevedo's Avatar
Manuel Azevedo
This is something you could just wait and see the condition of your heads now. Most of this hype on hard seats is just that! If your heads are good now after 39 years you add it all up and see if you really think it is worth the effort. Cost wise when you add the false seats to the equation you my be better off buying some better heads for better performance.
Mashman's Avatar
Mashman
Old Jan 11, 2012 | 12:20 PM
MelWff's Avatar
MelWff
Didnt GM start installing harndened seats in 1971 when the compression ratio dropped?
Old Jan 11, 2012 | 12:30 PM
brrujo's Avatar
brrujo
I dont really know when the hardened seats were introduced. I know it was in the early seventies. The reason I am pulling the heads is two fold. Valve seals and engine detail. The valve seals just give me a good excuse to pull the heads!
Old Jan 11, 2012 | 12:32 PM
MelWff's Avatar
MelWff
If your only problem is burning oil because of seals they can be replaced without pulling the heads.
Old Jan 11, 2012 | 12:34 PM
billla's Avatar
billla
St. Jude Donor '14
I've seen very, very few cases of seat recession in old heads fed a steady diet of unleaded for decades.
Old Jan 11, 2012 | 12:55 PM
Mike Ward's Avatar
Mike Ward
That's correct- all '73s came from the factory with hardened seats. The change was a precautionary measure purely for the upcoming removal of lead from fuel, not directly associated with the reduction in compression ratio.
It turns out that the hardening of valve seats on Corvettes or similar cars was unnecessary- the engines never run hard enough for long enough to create the conditions required for valve seat recession. There are some that still believe it to be required despite 40 years of evidence to the contrary.
Old Jan 11, 2012 | 02:01 PM
fanmanbd's Avatar
fanmanbd
73 does have hardened seats.
Old Jan 11, 2012 | 09:44 PM
Indiancreek's Avatar
Indiancreek
If in doubt lay a straight edge across the valve stem tips and see if any are taller than others. Open the valves about 3/8ths an inch or so and see if there is any lateral movement to check guide wear. If there is lateral movement of a fair amount, do the valve job and guide attention. otherwise change the seals.
Old Jan 12, 2012 | 09:06 AM
Tom454's Avatar
Tom454
I was in business as a professional engine builder for over 30 years. I am still doing head work. It was all hokus pokus... The Sky Is Falling... from the contingent opposed to unleaded fuel. Recessive valve seats are -typically- the result of an unskilled mechanic getting over ambitious with the seat cutter.
Old Jan 12, 2012 | 09:30 AM
Indiancreek
I don't want to get a debate started on this thread, but I've torn down sbc engines for the first time, having soft seat heads, and found the exhaust valves into the chamber roof completely below the surface. Not often, but I've seen it never the less. Never seen intake issues, only the exhaust. So it would indicate a heat related issue.
I think stainless valves would benefit the a soft seat head rebuild.
Old Jan 12, 2012 | 09:59 AM
Tom454's Avatar
Tom454
Originally Posted by Indiancreek
I don't want to get a debate started on this thread, but I've torn down sbc engines for the first time, having soft seat heads, and found the exhaust valves into the chamber roof completely below the surface. Not often, but I've seen it never the less. Never seen intake issues, only the exhaust. So it would indicate a heat related issue. I think stainless valves would benefit the a soft seat head rebuild.
... and not necessarliy caused by soft valve seats. An overheated mushroomed valve can recess a seat... hard or soft. This is discussed in detail in some of the industry literature.
Old Jan 12, 2012 | 10:28 AM
Indiancreek
It's like most things, I have publications from an Engine Builder publication I subscribe to that explains the micro welds that take place and lift small particles from the seat and in time, erase the seat to depth. So, I think it's what ever expert one chooses to believe. There is a reason new heads have hard seats. The auto industry wouldn't spend the cash for hard seats if there were not a reason.
Old Jan 12, 2012 | 10:36 AM
Mike Ward's Avatar
Mike Ward
Yes that publication is correct- the microwelding can and does occur and will lead to valve seat erosion. The key is that Corvettes do NOT run their engines hard enough for long enough to raise metal temps to the level required for this process to initiate.
Dad and his fully loaded Vistacruiser pulling the Airstream trailer over the Rockies in July might have a problem.
To Hardened Valve Seats
