Rebuilt differential
Old Jan 12, 2012 | 09:20 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Default Rebuilt differential
Anyone have a source for rebuilt differentials? I was told my '80 may need some serious rear end work and I am investigating my options. Nothing fancy, just a parts replacement is what I'm looking for. Standard factory 3.55 posi setup just like the General built it. Thanks!
Old Jan 13, 2012 | 07:20 AM
speedreed8's Avatar
speedreed8
forum vendor
http://www.ikerds.com/miva/merchant....t_Code=300-000
Old Jan 14, 2012 | 12:30 AM
Gale Banks 80''s Avatar
Gale Banks 80'
The General Built Your 80' with a 3.08 Gear Ratio. As the 80-82 Dana 44 dosn't sell for much on the Used Market You may look for a replacement.
Old Jan 14, 2012 | 03:14 PM
CaseyJones's Avatar
CaseyJones
As I understand, the General built '80 automatics with 3.55 and 4 speed cars with 3.08 but I have conflicting information. I turn way to many rpm's to have a 3.08. Correct me if I'm wrong, but I'm going by the AIM as it mentions the 3.55. The car turns close to 3K rpm at 60 mph on stock wheels and tires. The window sticker does not mention the rear axle ratio but it is an L48 automatic with Gymkhana and 48 state emissions. How can I tell?
Old Jan 14, 2012 | 08:57 PM
stinger12's Avatar
stinger12
I'll send you a PM.
Old Jan 15, 2012 | 12:27 AM
Gale Banks 80'
This is not a very accurate way to figure the ratio but that would work out to a 3.90 Gear. If You check out the Numbers on the bottom of the Diff it will tell You the Gear Ratio it had when it left the Factory.
1980 3.07 has a OF or OH
1981 2.72 has a OK
1981 2.87 has a OJ or OA
1982 2.72 has a OA or OF
This is from the Corvette by the Numbers book. I will say that there must be something wrong with the 81 82 OA code. The Code should be the same Ratio for both Years.
Old Jan 15, 2012 | 09:26 AM
gbarmore's Avatar
gbarmore
FWIW I have an '80 automatic L48 car as well, and it's all original as it came from the factory. The Diff is out for a body off so I have easy access to this test. When I turn my side output yoke 1 revolution I get just a hair over 3 revolutions on the driveshaft input yoke indicating a 3.08 rear.
Old Jan 16, 2012 | 02:56 PM
qwank's Avatar
qwank
Originally Posted by speedreed8
Anyone have any experience with this vendor? I'm planning on a Diff replacement in a few months also.
Old Jan 16, 2012 | 05:46 PM
willem wallace's Avatar
willem wallace
Default Diff Rebuild
Not sure if he is still involved with the forum, but do a search for Gary, I think his forum name is/was GTR or GaryGTR. He does real nice work on the earlier c-3 diffs. If you cannot find his info, PM me, I have his number somewhere. Excellent quality work.
Old Jan 16, 2012 | 06:10 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
He cannot see posts on this forum and he does not work on 1980 differentials.
FWIW, the OP has a 3.07 geared diff. if it's original.
Les
Old Jan 16, 2012 | 08:29 PM
bhk2's Avatar
bhk2
I see they sell a front suspension rebuild kit, my next project. Has anyone purchased this kit and can make a recommendation either way-mostly concerned with ball jointsand pitman arm.
Old Jan 16, 2012 | 08:48 PM
joewill's Avatar
joewill
if you want a standard build with new clutch packs, new bearings, coorrect setup, prepare to pay about 800 at the main vette parts houses. then plan on them milking your core charge for a much as they can to reduce your core charge.
but a standard build will last you 100K miles.
the lower the ratio numerically, the lower your rpms will be at cruising speed..
if you are running 3000 rpm at 60 MPH, you do not have a 3.08, i bet somewhere in the 3.73 4.11 range. which means your rear end has probably been apart in the past.
also factor in a error possibility.. are you really running 60 MPH, are you really running 3000 RPM? torque converter lock up?.. all sorts of factors are in play here.
Old Jan 16, 2012 | 10:34 PM
CaseyJones's Avatar
CaseyJones
I need to get her out and offer a more accurate speedometer/tachometer relationship. To be a little more accurate, the car is turning around 2700rpm at 60 mph. I'm running the stock 350 turbo with lockup and stock size tires. My owners manual shows 3.07 as standard but AIM has 3.55 as optional. The broadcast sheet does not show an optional ratio installed at the factory, so I am genuinely confused. With a 3.07 I would assume something around 2200 or 2300 at 60. I really need to investigate this further on my car...
To Rebuilt differential
