Horn contact problems
I've rebuilt the rest of the T&T column on my '79 but the whole horn contact is rigid and doesn't move, the horn also does not blow.
Any idea of what I may have done wrong or missed?
I am thinking that possibly the lack of shim(s) #6 could cause the cap assembly (#9, #10, #11) not to be able to move because it is touching lever (459083) before the upper horn contact (#7) is closed and grounding the horn circuit.
You should be able to press on the horn cap, close the contact, and blow the horn without the horn cap touching or scraping on the telescope lever.
Otherwise, the upper horn contact #7 may be corroded and may need to be rebuilt or replaced.
Jim
I'm still having the issue with the hazard lights wherein they engage but don't' disengage, any idea what that may be? This whole steering wheel column thing is a nightmare!
EDIT: So I've found that the wheel CAN blow if, for example, you complete the circuit by touching the brass parts exposed by the locking plate with a wrench. However, once I put the retainer on the wheel refuses to blow again from the HUB ASM. That appears to be where the problem lies.
If you just take off the steering wheel, you should be able to ground the eyelet tip to the steering shaft. Your horn should blow. If grounding the tip does not blow the horn then your problem is down inside the column, down in the wiring, the solenoid, or the horn themselves.
If the horn does blow, then the problem is in the upper horn contact itself.
Jim
This is the retainer I bought, is it compatible or should I go for a more standard one? (The yellow one that Eckler's sells.) http://www.amazon.com/gp/product/B00...00_i00_details
I would think that the plastic retainer that you show should work. I assume that it is dimensionally the same as the OEM part. The plastic legs on the retainer should straddle the brass contacts that stick through the locking plate. The big spring that is part of the hub should sit down on the brass contacts and the plastic retainer should prevent any other metal steering column parts from touching the spring.
When the parts are assembled, you should be able to place one lead from a continuity meter on the tip of the eyelet. You should find continuity down through the steering column to the black horn wire that is located in the "G" location in the middle of the "harmonica" plastic connector under the dash.
Jim
I'm going to try and file down the legs on the retainer I have now and see if that works. Wish me luck.
With respect to the plastic horn tower that extends up through the steering wheel hub. The parts inside the horn tower should be the spring, then the eyelet with the upset end against the spring. Then the plastic bushing that holds the eyelet and spring in place. You should have continuity between the end of the eyelet and the metal steering shaft. You should be able to depress the eyelet into the horn tower and still maintain continuity.
Jim
