68 wiper motor / washer motor confusion
Somehow I just don't get it or I am missing a part. The washer mechanism mounts to the wiper motor housing. But I do not see how they work together. There does not seem to be a connection between the wiper motor and the washer mechanism. What spins the plastic cam on the washer mechanism? If anyone has some insight that would get me on the right path to understanding this I would appreciate it.
You need to line up this hole
With this one
Insert a more suitable sized pin than the one I have here.
Then you just bolt the cover to the motor and pull the pin out.
With this one
OH, NO! This is probably great advice and if it is I have a problem. I just bought the washer from a forum member. It does not have the white plastic part on the back side. It just has the shaft with the ring around the top for the clip. No wonder I couldn't figure it out. I am sure it is a honest mistake so I will contact him immediately.
I'm sure Sarge is correct about being able to get repo parts but if you need anything from my spare let me know exactly what you need and where to send'em.
http://i13.photobucket.com/albums/a2...k/118_5259.jpg
I really appreciate the help. If you have the 4 lobe cam in your picture and the clip that holds it that would be great. I assume that is all that is there. Let me know what you want for it and I can see if the guy I bought it from will take care of it. He seems to be a good guy, just didn't know it was missing.
Former Vendor
Received 1,816 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You may be able to get this from a core in a junk yard on an older passenger car too!
DZRick,
No charge.
That's great! Thank you very much! Hopefully somehow I can repay you when I'm selling something. If there is anything specific you need let me know. I don't have much but I do have some. Thanks again.
He is a good guy.
He got a hold of me as soon as he realized there were parts missing from what he sold you asking if I had spare parts so he could make things right.
We '68 owners have to stick together!
Former Vendor
Rick, does this mean I'm the odd man out? I don't have a 68 ;(
AWilson.. one thing you might do is check the make sure the pump runs. I'm sure you have but just a reminder... I'd hate to see you do this work and it not run.
As far as I'm concerned you are an honorary member of the '68 club!
Former Vendor
I can still ride shotgun.. Thanks Rick, but remember you found the missing wire...
My pleasure, happy to help both you and the gent that sold you your pump.
He is a good guy.
He is a good guy.
I will be doing that tomorrow. I assume I just apply + and - to the female pin leads on the washer? Does the pump have to be full or at least wet or can I just bench test? I don't want to be able to say it DID work!
Update
Got the extra parts needed. Tested the wiper motor using the Wilcox video and it works. After much clean up and lubrication I tested the washer mechanism and it seems to work fine! New plastic cap makes it all look nice and we are done! Thanks to everyone's help.
Yeah all of us with 68's seem to need some help with one thing or another on here at some stage. Good to see you managed to get it sorted. Me, I'll be going over these threads this weekend comparing the pics and descriptions to my 68 washer that is permanently on when the motor is running (and it ain't the switch).
