Roller rockers????
Old Jan 20, 2012 | 02:19 PM
Xterrable's Avatar
Xterrable
I am in the same sort of boat. (Not to hijack the thread)
The PO changed verything but the heads on my 74 350. So I am going to do a mild top end refurb and throw new heads on it. Looking at the E-Street heads right now. So do you suggest just swapping my current rockers from my stock heads or going to rollers? And stamped rollers are out of the question? Was not expecitng to pay an extra 300 on the top of heads... Anyone know what specs I would need if so?
Old Jan 20, 2012 | 02:36 PM
ezobens's Avatar
ezobens
If money is a concern and your current rockers aren't excessively worn, there is no reason why you can't use them even though most folks would put new rockers on new heads just on principle.
Rockers are easy to replace at anytime so it's up to you.
Stamped rollers have their place (even though most folks don't care for them for some reason) so again, it depends on what you are trying to get out of the motor and how much you want to spend.
Stamped rockers on an otherwise stock motor are pretty bullet-proof.
Roller tipped rockers offer a little more strength and perhaps a more accurate ratio but I wouldn't use them on a High HP motor.
Full rollers are if you want/need the best without going to shafts.
Elm
Old Jan 20, 2012 | 03:22 PM
Xterrable's Avatar
Xterrable
As far as my goals. I should be aiming for low to mid 300 Hp when I am done. Nothing radical. Looking to bump the compression up a bit over the stock 8.5:1. Aiming more towards torque.
EVERYTHING has a budget. Or does it....... Heck, this was just going to be a head gasket fix. At this point I am 500 in the hole and I have not even taken 1 bolt out of the motor. HaHa. Took everything out, bebuilt the front suspension, detailed the bay, bought headers. Trust me, I would rather see the car sit for a year rather than put it back together and kick myself for not spending the extra hundred. But trust me, I know all too well. 100 this week, 100 next week. 100 the week after that... End up with a lot of explaining I need to do.....
Old Jan 20, 2012 | 05:44 PM
ezobens's Avatar
ezobens
Yeah, my budgeting skills are out the window-
I started after the holidays with just wanting to have my heads ported for a little more power and now I've bought new heads, rockers, headers, intake, carb and a new oil pump.
I need help.......
Old Jan 20, 2012 | 06:32 PM
Xterrable's Avatar
Xterrable
I need help.......
Apparently we have very different wives...
Old Jan 20, 2012 | 06:39 PM
ezobens's Avatar
ezobens
Oh, yeah.. Well, I don't actually tell my wife what I'm buying...
What happens in the garage, stays in the garage...
Like the saying goes-
When I die, I hope my wife doesn't sell all my toys for what she thinks I paid for them!
Old Jan 20, 2012 | 06:54 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Originally Posted by Ben Lurkin
yes, but you will need to install taller valve covers or double gasket your existing ones to gain clearance for the lock nuts. You should also check your valvetrain geometry.
If you're just changing them for the sake of having roller rockers, save your money and leave the stock rockers on.
In my opinion, very good advice Ben.
Old Jan 20, 2012 | 07:26 PM
great68's Avatar
great68
I guess I'll just kick back for a little while, save some money, and read the stuff everyone has to say and by then I might deside to go with a 5 speed!!!!!! Tha motors plenty quick
Old Jan 20, 2012 | 07:33 PM
ezobens's Avatar
ezobens
If the choice was roller rockers or a 5-Speed, I'd take the 5-Speed!!
Old Jan 21, 2012 | 10:50 AM
69 Chevy's Avatar
69 Chevy
And if a 5 speed trans were the same price as a set of roller rocker arms, buy both. But they're NOT. Not even by a factor of 10.
There's been quite a bit written on mouse motor OEM rockers not measuring up to what ratio they're supposed to be. I've read that most are 3.8 to 4.2:1 when the factory specs call for 1.5:1. So even installing inexpensive aftermarket roller-tipped rockers will produce a horsepower gain since they claim to be true 1.52:1 ratio. And since the valves open farther, more air/fuel gets in/out to produce more power.
I have not read of the same situation with the rat motor's 1.7:1 ratio however.
Old Jan 21, 2012 | 11:06 AM
Xterrable's Avatar
Xterrable
*NOOB WARNING*
What are the ratio's? And how are they calculated? How how do oyu know what you need?
Old Jan 21, 2012 | 11:45 AM
LAddams's Avatar
LAddams
It describes the transference of the lift from the lumps on the cam to the valve. For simplicitys sake say a camshaft has 1" of lift. A 1.5 ratio rocker would push the valve down 1.5" when pushed up on by the 1" lift cam. For a theoretical 2" lift cam the 1.5 rocker would push the valve down 3" and so on. So a 1.7 rocker would give you more lift with the same cam than a 1.5 ratio rocker.
Old Jan 21, 2012 | 01:34 PM
  #33
great68's Avatar
great68
Thanks LA for letting me know how the rockers and cam works. Thats neat I didn't know just how that works I mean you made it easier to realize just how the math of it works.
Old Jan 21, 2012 | 02:16 PM
  #34
LAddams's Avatar
LAddams
No problem, when Xterrable asked I thought well theres finally something in my rusty old brain that someone here wants to know!
Been learning so much on this forum while its too cold to start work on my project car.
Old Jan 22, 2012 | 08:21 PM
  #35
Xterrable's Avatar
Xterrable
Thanks. When it comes to working on cars, I usually ask for a hand from my buddy. But he not the teaching type. Once I make a mistake he just takes over. Works well in some situation but it bites me when he is not around..
So how do you know which ratio rockers you need?
Old Jan 22, 2012 | 09:13 PM
  #36
LAddams's Avatar
LAddams
Lol that part of my info is 25 years out of date. Back then rollers were an expensive vanity choice and if you wanted more lift you bought a lumpier cam!
The roller rockers in the engine of my new project car were an unattainable daydream last time I put a wrench to the insides of an engine!
Tech has changed Im sure someone can give you a better answer
Old Jan 23, 2012 | 01:05 PM
  #37
great68's Avatar
great68
I'm with Xterrable, how do I know what rocker ratio to use?? Looks like 1.7 would give the best HP right?????
To Roller rockers????
Old Jan 23, 2012 | 01:11 PM
  #38
Xterrable's Avatar
Xterrable
Naa. 1 out of 2 isnt bad. HaHa.
About 15 years ago, my old next door neighbor tried teaching me all about cars. I got through most of the mechanics but when it came time for the motor building, Imy mind was on to Girls 101....
Old Jan 23, 2012 | 01:37 PM
  #39
DRIVESHAFT's Avatar
DRIVESHAFT
For a big block, 1.7 is the stock ratio.
Most just stick with that unless they are really going racing.
Old Jan 23, 2012 | 01:38 PM
  #40
Rally68's Avatar
Rally68
Depends on a lot of things. First of all, you have to have cam, heads & carb that can benefit from and take advantage of the extra lift. Also keep in mind those 1.7 rockers move the pushrod in A LOT...you have to make sure you won't have binding issues, this is a very common issue with higher ratio rockers. Also you need to have the right springs; you are not only multiplying the valve lift but also the spring pressure that the cam lobe "sees"; conversely, if you don't have enough spring, with that much lift, you'll get valve float.
...I've never put anything like this together but I imagine you could wipe a lobe real easy if you weren't careful about your choices--maybe the guys who build a lot of these things could comment?
>>never mind, I was talking about small blocks, I just looked at your avatar and see you have a BB
