Holley carb question
http://en.wikipedia.org/wiki/Carburetor
http://www.popularhotrodding.com/tec...k/viewall.html
http://www.bob2000.com/carb.htm
http://www.carcraft.com/techarticles...e/viewall.html
http://www.junkyardgenius.com/holley/tune01.html
http://v8tvshow.com/content/view/110/28/
http://www.nastyz28.com/~ericf/tech/htune.pdf
http://www.youtube.com/watch?v=6KjjN...eature=related
http://hotrodscott.blogspot.com/2007...ingtuning.html
Here's a good book about Holley carbs. Go down to your town library and ask if they have it. If they don't, they can get it from another library and let you borrow it for a few weeks. Read it from cover to cover.
http://compare.ebay.com/like/2203533...Types&var=sbar
Good luck!!
Scott
Good luck!!
Scott
Thanks!
However, I can usually stumble along and get a carb running well, not because I am an expert on carbs, but because I did a little studying, and I know how carbs in general work. I mean the basic principles of how a carb works. And they all work the same way. Basically, it's all about differential pressures. They seem complicated and fussy, but once you know the basic principals of how they work, you will see that they are actually pretty simple devices. However, these basic principles can be a little tough to wrap your head around, at first. It is well worth the time and effort to learn the basic principles of how carbs work, though, even if it's just so that when you eventually do have a problem you can't figure out, you will be able to understand the answers you get from a real carb expert. Like I said before, I'm not a carb expert, but I do have the ability to have an intelligent conversation with one. And, I stayed at a Holiday Inn last night, so I got that goin' for me, which is nice.
Scott
Scottyp99 and I have the same carburetor, our paths have crossed on the forum and we have scoured the internet for enlightenment.
From Lars, I learned that "Most carb problems are really timing or ignition problems." That was a hard one. When I rebuilt my Qjet with the information from Lars, Cliff Ruggles and Doug Roe, I was tuning for performance. Lars advice to me was to use manifold vacuum for my advance and it worked like a charm.
Then, I bought a used Holley 4160 600 cfm to put on my 350. I couldn't get the carb to run right. Now I was tuning for problems. First, it backfired. Holley made that easy to fix. Then, it would hesitate under light acceleration. I spent a lot of time trying to adjust this out of the carb. Then, taking advice from yet another kind expert, I plugged the vacuum to the ported supply on the carb. That is all it needed to work perfectly. It was the last thing I could think about. However, it confirms another old saying which is "Tune to what the engine needs, NOT what you think it needs."
On a final note, a friend of mine has the same 600 cfm Holley on a Ford 429. Please don't tell my Vette that for fear it may protest.
Scott
Scott
