Rear brake issues. Ideas?
Anyway, scored one of them on just the outside face by touching the caliper somewhere. Only went about 1/2 a block and came back.
Turns out he mixed a front and a back, the front worked on the back but the back didn't work on the front (or maybe the other way around)
I went over to his place and we did a lot of head scratching until we popped off all the wheels and started checking and that's what the problem was, two opposite corners ended up switched (visually looked the same until you actually started measuring and putting them up to each other)
Might be worth a check, it looked a lot like that photo
Mooser
Shouldn't be this issue (front/rear) if they were fine before.
You've replaced the caliper so let's go with that being ok.
Your calipers are nicely painted, can you see what was rubbing on the rotor?
If it's the pad that's doing the damage, check to see if there's any foreign materials stuck in it, maybe picked us a small stone or ???
Is the brake sticking on? Check the flex line, been known to rot on the inside and act like a one-way-valve. Personal experience with that one, not every time but frequently it would lock the fluid in the caliper and leave that brake on, looked new from the outside but all torn looking on the inside.
Broken or loose caliper mounting bracket / bolts?
Excessive play in the spindle? (not sure about this) if the spindle was somehow moving outward it would take the rotor with in but the caliper would stay still. Don't know how that would happen, failed bearing or worn spindle
Not sure what else could mark the outside of the caliper like that.
Did anything chance when it went from good to bad?
New tires, rims, shocks, bump a curb, gain 100 pounds? Change something totally un-related?
How's the clearance on the caliper with the wheel off can you see it what might be touching?
If someone applies the brakes can you see anything move/twist on the caliper?
Just some random guesses
Funny you mention the flex line. A buddy of mine just brought that up a little bit ago. Gonna pick one up and replace it. Shouldve done that anyways.
No play in caliper when tightened. After i bolted it back together the other day it was nice and snug with no movement.
Gonna take a good hard look at the pad on that side next chance i get to be sure nothing got stuck in it.
Also, i did get new wheels & tires on it, but they were put on last sept. If wheels were the prob Im sure it would show up before now.
Also check your front rotor. You may well find a corresponding score on the inside face.
Any chance the pad had a wear-indicator tab on it that caught one of the rotor grooves and got pulled between the pad and rotor and is stuck there now?
I know, pretty weak..
Pulled the pads out and there appears to be plenty of spacing between the ear of the caliper and the rotor.
Next is the pic of the pad on the one side where the rotor is getting dug into.
Pulled the caliper off and saw what is causing the problem. The ears of the caliper, on the side closest to the wheel, is what's rubbing on the rotor. It is easy to notice since I had just painted the caliper before I put it on.
I checked the mounting bracket for the caliper and didn't find any cracks, and there was no play in it when I grabbed it and tried to move it around. The wheel studs are good and solid.
I don't see how the caliper would be moving around with everything seemingly solid. I didn't get a chance to have someone press the brakes to see if it moved, but the grinding noise that I heard when driving was constant, even when the brakes weren't pressed.
Could it be from the wheel not going on evenly? Allowing the rotor to wobble or just be crooked. I've put on and taken off wheels many times. It's not rocket science. Standard star pattern when bolting wheel on. I would like to think I'm not screwing that up, but.....lol. I appreciate the input.
Thanks.
Andy
If some crud fell behind the rotor, again it should have touched part way around
The mark on the rotor look to be all the way around meaning the rotor is straight out or the caliper is in.
The caliper is marked on both ends so it was on straight
Hate to go back, but are you sure a front and rear rotor didn't get switched?
You said freshly painted caliper, front and rear caliper switched? (not even sure if that's possible)
washer/lock washer between the mounting bracket and the caliper
Mooser
