"ROCK CRUSHER" TRANY?
Old May 12, 2002 | 05:21 PM
OkeeGuy's Avatar
OkeeGuy
Default "ROCK CRUSHER" TRANY?
back in the early 70's i had a 68 roadster (vert) and it seems like i remember the nickname "rock crusher" being used to reffer to the 4 speed trany...the Muncie i believe...
can anybody straighten me out on this one? am i recalling correctly or am i dreaming?
Old May 12, 2002 | 05:27 PM
Pete79L82's Avatar
Pete79L82
Default Re: "ROCK CRUSHER" TRANY? (SIGNGUY)
The rockcdrusher or M22 is the same trans as a M21 close ratio muncie with the exception of having much straighter cut gears.
This is an M20 - M21
This is an M22
Notice the difference in the angles of the gears, This was done to help with sideloading the cluster gear against the case. Straighter cut gears also take less HP to turn but are noisier, hence the name "rockcrusher".
Stingy74's Avatar
Stingy74
I think a rocker crusher was an m22. Had straight cut gears or something, I can't remember. I think they found their way into l-88 and zl1 cars.
Old May 12, 2002 | 05:28 PM
bence13_33's Avatar
bence13_33
Yes, there was a Muncie Rocker Crusher...if I remember correctly it was the M22. The gears in the tranny were cut slightly different which made them stronger than the normal Muncies. Hopefully redvetracer will chime in, he seems to know a lot about the Rock Crushers.
Old May 12, 2002 | 05:45 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: "ROCK CRUSHER" TRANY? (bence13_33)
man...is there ANYTHING that you guys dont know??!!??
thanx guys :)
Old May 12, 2002 | 06:39 PM
robzr's Avatar
robzr
The M22 "Rock Crusher" I believe has gears cut at a 22 degree angle vs. 45 for the M20/M21 (degrees from memory). M20 (wide ratio) had wide gear spread for use with taller rear gears, while the M21/M22 (close ratio) had the same narrower gear spread for use with a shorter rear end. I have read that the 45 degree style gears actually have more gear tooth contact at a given time which makes them stronger (contrary to popular belief). The M22 generates less friction which means less heat and lower temperatures, which is desirable for ROAD racing. This has been subject to some controversy.
If you have any questions, without a doubt the man to talk to is a guy named Wally who runs http://www.muncie4speed.com he is a regular on chevelles.com and knows his muncies. I think he is working on a 5 speed muncie right now.
Rob
Old May 12, 2002 | 06:58 PM
Alwyn678's Avatar
Alwyn678
Default Re: "ROCK CRUSHER" TRANY? (robzr)
They were put in quiet a lot of muscle cars including my 67 Firebird
Old May 12, 2002 | 07:14 PM
Indy Year 25's Avatar
Indy Year 25
I had a '71 Z28. I always thought it had a Muncie "T10" rock crusher. Was I misinformed?
The tranny whined. I loved it.
Old May 12, 2002 | 07:51 PM
Gordonm's Avatar
Gordonm
Default Re: "ROCK CRUSHER" TRANY? (Indy Year 25)
The T 10 transmissio nwas a Borg Warner unit. Muncies were either M20 M21 or M22 (rock crusher)
Old May 12, 2002 | 10:35 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
The vast majority of M22's produced were sold over the counter rather than being installed in cars at the factory. I've lost count of the number of times someone has claimed his tranny was a "Rock Crusher". In most cases, they learned that they had a Muncie and their fantasies went from there :). Years ago I went to look at a modded late `70's Camaro that had been advertised as having a "Rock Crusher" trans. It sure sounded like one but it turned out to be a worn out Saginaw box :).
Old May 12, 2002 | 11:29 PM
67HEAVEN's Avatar
67HEAVEN
Default Re: "ROCK CRUSHER" TRANY? (Vetterodder)
Whattaya talking about. My 1966 SS427 Corvair came with a special mid-mounted M-22 rock crusher along with twin Paxton superchargers and cross-drilled rotors at all four wheels. The guy that sold it to me swears that this was a COPO car built specially for Ralph Nader. It was heater and radio delete so I believe him. :jester
Old May 13, 2002 | 01:48 AM
Wrencher's Avatar
Wrencher
Default Re: "ROCK CRUSHER" TRANY? (67HEAVEN)
Anyone that's ever driven a car with an M-22 "rockcrusher" (me) will tell you that they are NOISY! It's kinda like side pipes: you don't need a radio because you can't hear it anyway. If it goes by with a whine like a blower, but different, it's a rockcrusher. You don't need one unless your racing... Heck, the new 5 and 6 speeds are way better.
Hans
Old May 13, 2002 | 01:58 AM
BDAZVET's Avatar
BDAZVET
Check out May`s Car Craft. Make your own Rock Crusher. That guy`s five speed may be just around the corner. :cool:
To "ROCK CRUSHER" TRANY?
