First off, what is a "tall deck" 427? Someone has two 4-bolt 427 blocks for sale, and that's what they are. He also has steel cranks, oval port heads, roller cam and lifters, pushrods,etc. and a complete running 2-bolt 454, all for $1,500. He said the 454 burns oil, so it probably has to be bored out. What do you guys think?
Personally I would stay away from tall deck motors. The reason they are tall deck motors is because the piston in the motor has 4 rings instead of three. If the 454 smokes it doesn't mean that it needs bored out, maybe just new rings. I would go with the 454 and stay away from the tall decks.
Tall deck refers to the distance from the centerline of the crankshaft to the surface the heads bolt on to. A standard height big block is 9.800. A tall deck block is 10.200 which allows for either a longer stroke crankshaft or longer connecting rods. Tall deck blocks will require either intake spacers or a intake manifold specific for a tall deck.
Unless you want to make a lot of cubic inches there is no need to go to a tall deck. It can cause problems fitting into a corvette but nothing that can't be overcome. Because it is .400 taller it can cause hood problem and clearence problems around the brake booster. As the block gets taller it speads the heads farther apart which can cause problems with exhaust and headers. Again these are all problems that can be overcome but take extra time and money.
That would leave the deck fairly thin and could lead to head gasket sealing problems. Also some of the early tall deck blocks did not have blind head bolt holes so that would leave .400 less material for the head bolts to hold to which could cause them to pull out.
The tall deck motors were used in heavy duty trucks but not in pick ups. Because they can accomodate a longer stroke than standard blocks, they've been popular with the "mega cube" builders. As already posted, their increased height and width prevent them from being used in Vettes without some serious mods.
Let me get this straight. he wants to sell ALL of it for $1500.00? Seems you could sell all the stuff you don't need and end up with a pretty inexpensive 454. Just depends if you want to do the swap meet or E-bay thing...
The stroke will not affect the top dead center location of the piston. If you install a 4.25 inch crank in a tall deck block with standard rods and pistons the TDC point will still be down .4 inches in the bore. what you do is use a longer rod. To my understanding a longer stroke is not the reason rodders use tall deck blocks. They use them so a longer rod can be used which raises the rod/stroke ratio. this slows piston speed and helps reduce pressure on the piston sleeves. aka... High revving machine!!!!!!!!!!!!
But the question is, is there a market for tall deck 427 blocks...? There's only one on Ebay right now, and it has no bids. I know it would be a good deal if I had the time and money to build both of the 427's and sell them, then use that to pay for performance parts for the 454... but I don't have the extra cash and not much time, either. I really don't know what to do.
Jerry
Yes, there is a market mainly for people who like to drive in straight lines for about 10 seconds........... 1/4 mile racers...... :D
4-bolt blocks usually sell for around $500 each around here as long as they're in good shape. Tall blocks don't seem to bring more money that standard blocks.
So theoretically I'd have a $500 running/smoking 454. Maybe he'll take $1,300... Well, I'll give it a try, seems like it would be worth it. Even if I didn't use the 454, I could rebuild it and sell it to make some money for my 350. :D
