72 LT 1 engine question???
Old Jan 28, 2012 | 12:10 AM
20mercury's Avatar
20mercury
Default 72 LT 1 engine question???
I got a 72 with a LT1 engine and have a question on the intake manifold.
Heads, block, carb all check out as original, but it has an Ederbrock Torker aluminum intake manifold instead of the original GM 3959594. I checked and the Ederbrock is a "single plane"? Was the GM a single plane? What is the advantage of a single plane? and finally why would anybody go to the trouble to just swap out the intake manifold? Are the aluminum intake manifold prone to corrode out? No headers, original exhaust manifold too.
Much thanks if anybody has any insights!
Old Jan 28, 2012 | 12:52 AM
billla's Avatar
billla
St. Jude Donor '14
The stock LT-1 (not LT1) intake was a high-rise, dual-plane intake similar to the Performer RPM.
The Torker is a low-rise single-plane.
Dual-plane intakes provide better low-end torque and throttle response at the expense of top-end power. Single plance give up some low-end torque and throttle response to provide better top-end power. The Torker is a compromise to some extent - as a low-rise it tries to maintain better low-end torque while still providing high-end power. Overall, a high-rise dual-plane is the best choice for street engines making around 1-1.2 HP/CID.
I can't imagine why anyone would swap out the original intake; it's a decent street intake even today. I have a GMPP replacement item and an original that was installed on my '69 L-46. They're reasonably easy to find and not terribly expensive if condition and dates aren't important.
All IMHO, of course
Old Jan 28, 2012 | 01:50 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
All IMHO, of course
We used to grind the center divider down abot 1/2" on those back in the 70's to get more top end out of them. Ported a bunch of them out as big as possible too. They were the hot intake setup in the day. Date coded ones that are still factory correct are probably a lot rarer because of guys like me.
Old Jan 28, 2012 | 02:19 AM
Solid LT1's Avatar
Solid LT1
It wasn't uncommon to see swapped intakes on LT-1 motors (Camaros and Vettes.) Edelbrock claimed 20HP increase with Torker, I would say more like 10-12HP max with big low end torque loss and bad fuel distribution for an extra bonus.
I remeber reading about a 19HP increase for a 2plane Performer RPM over GM hi-rise, we observed around 6HP in the dyno testing of one of my motors way back when. I elected to run the GM hi-rise, Vette went 12.28@117MPH with a 1/2" spacer and stock plenum divider in it. That same Vette went 12.60's with ported iron exhaust manifolds. I used to enjoy the reactions of people checking the motor out in the staging lanes with the 12.75dial in on the windows, they were FREEKING at the stock looking motor (it had a lot of internal work done to it and a decent roller cam that ate lifters on a 5K mile basis.)
Old Jan 28, 2012 | 10:47 AM
20mercury's Avatar
20mercury
Default Ok and much thanks!
Ok and much thanks as this is quite informative! I am guessing somebody was looking to get more hp, the usual suspects
I am going to start looking for a GM 3959594, a quick check looked like they are expensive, and some brag that the thermostat hole is still good (think I got that right), does this corrode out?
Old Jan 28, 2012 | 11:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 20mercury
...some brag that the thermostat hole is still good...does this corrode out?...
No. People pull the threads out of the water neck mounting holes.
Are you considering having your car judged? If so, you will want a correct date for your manifold.
Can you contact the previous owner of your LT-1? He/she might have the original manifold pulled off for the Edelbrock.
Good luck with the hunt.
Old Jan 28, 2012 | 06:02 PM
spdrcr29's Avatar
spdrcr29
There is one on ebay right now. Item# 190629123914. It's current bid is at $212.50...
Old Jan 29, 2012 | 11:00 AM
20mercury's Avatar
20mercury
Default Thanks for the tip!
Thanks for the info on threads and the ebay tip, I see some advertised for $600, But they must come with gold plated intake manifold bolts!!!
(Now there is capitalist idea, make available gold plated intake manifold bolts, likely would be the cheapest replacement part on the Corvette!)
Old Jan 29, 2012 | 11:04 AM
Mike Ward's Avatar
Mike Ward
Casting dates on aluminum intakes are underneath and as such are not judged. Casting number is judged though was well as the usual configuration and condition.
Old Jan 30, 2012 | 12:03 AM
20mercury's Avatar
20mercury
Default Much thanks!
Much thanks for all of the feedback, comments and casting date info!
Old Jan 31, 2012 | 12:42 AM
Solid LT1's Avatar
Solid LT1
Late 71-72 LT-1 intakes have cylinder numbers cast into runners at port entry into head. BEWARE! that GM made a later crate motor aluminum intake that also had this feature but, also had a wide flange at the intake mounting face where the LT-1 intake had no flange extension above the intake port runners. That should help if your walking through a swap meet quickly scanning for a proper intake.
Old Jan 31, 2012 | 12:38 PM
billla's Avatar
billla
St. Jude Donor '14
As noted, I have one of the GMPP LT-1 style intakes (P/N 10185024) and I see them passed off all the time as a "factory" LT-1 intake. Note the differences in the pics below (fresh from the shop ) - especially how different the Winters "snowflake" is, the tapped boss at the front, no breather tube pad, bowtie on the back near the P/N....definitely need to be careful if you're looking for something NCRS-ready...
Old Feb 1, 2012 | 12:29 PM
20mercury's Avatar
20mercury
Default Good info all!
Good info all! Thanks for all of the feedback.
To 72 LT 1 engine question???
