1982 CE issue.. strange one..
I just picked up an 82 CE that is in decent shape overall.
Needed some TLC of course and I have been banging on it for about 2 weeks now.
IOt is a crossfire and I have been having a strange issue with it.
I am a pretty competant mechanic. I have replaced both IACS, TPS, CTS, And that seemed to settle the majority of the issues down..until I make a right turn.
The car will start and run (on a whim it seems) It started right up this morning after I replaced the TPS as it was causing issues at idle.
It started cold, rocked up to about 1K, then settled in at 700rpm a minute or two later.
Everything seems perfect.
I drop it in gear and go... accelerates great, idles down fine.. then I make a right turn and bang. Everything shuts down... I try to start it and have no fuel.. there is fire but no fuel, nothing sprays at all.. nothing drops, nothing dribbles.
This has happened before and sometimes it would start again.. other times it won't but the common denominator is not a drop of fuel is reaching the engine.. and it is after a RIGHT turn.
Figured i would check and see if there is a common problem with a wire harness or some other issue that plagues this model.
Anyone have any ideas?? This thing is killing me here.
I have never seen such a mess.. wow.. it was running just fine this morning.. until I made that right turn.
I just changed my cam, and refreshed all of the sensors, my car is running excellent now!
I had the fuel pump out yesterday.. it was a newer unit, hose was good and pressures are good with power applied.
I traced the hoses back yesterday. I also Tested the oil press. sw. in place and it checked out.
I disconnected the battery earlier and removed the ECM cleaned the connectors and re-assembled. It seems to have done the trick as it starts and runs fine now.
I prob. just put 40 miles on it with LOTS of right turns.
I really like my 87 Z-51 much better, 60K on the clock and it runs perfect.. not quite the dog this 82 is either..LOL.
I do get lots of comments on it out and about though. I picked it up pretty cheap not running and I figure I'll make it as right as I can get it and turn it over.
I appreciate the responses!
I have a friend who worked on nothing but vettes for 27 years.. most times I can tell him a symptom and he tells me what it is..LOL.
He was not available and I had no idea if there was a common problem with this unit in a right turn. (chafed wiring) etc.
I believe what was happening was that the connector to the ECM was loose on one of the pins and the wires moving in a turn was enough to shut it down.
Seems to be running fine now...
I now shut it down and the fuel pump will not stop.. it keeps pumping away.. If i disconnect the harness and re connect it, it stops.
It will keep running even with the fuel pump relay pulled. When the car is shut down.
So I drive it, sut it down .. and the fuel pump keeps going until I break the connector apart, then it will stop. Any Ideas?
I will look over that harness and see if someone did.. this is something i think it just started doing, is there any way this could be ECM related? ETA: it seems to me that if that were the case.. breaking apart the connector would not stop it... it would start right back up again when it was plugged back together.
It doesn't... it stops, then i can put the plug back together and it is off.
