Head Light Problems
Old Jan 29, 2012 | 06:51 PM
dkillins's Avatar
dkillins
Navigator
Default Head Light Problems
I have a 1980 Vette - when the head lights are on bright - all 4 lights are on - when I dimm them all 4 go out.
Which 2 should be the brights - from what I have read it should be all 4 - the the low beams should be the 2 outside lights. Is this right and if so why are the brights working and the low beams not working?
Any help is greatly appreciated.
Old Jan 29, 2012 | 08:39 PM
Peterbuilt's Avatar
Peterbuilt
Default It could happen!
Are you sure both low beam bulbs are not burnt out?
Old Jan 29, 2012 | 08:41 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Could be a dimmer switch or connection at the bulb issue.
Best way to find out is to pull the connector pictured below and test for voltage with the lamps on low beam. If you have power, then you need bulbs.. If you don't then you have a break.
The wires jump over and if the wire is broken it will take out both low beams.
To Head Light Problems
