Wobble at 55 mph, need some help
Old Jan 30, 2012 | 12:34 PM
Surfer69's Avatar
Surfer69
Default Wobble at 55 mph, need some help
Been fighting this problem for a while now, thought it was gone but it's not. Trying to figure out if my rear wheel play is acceptable or not. Need to ask someone here to try something for me.
When I jack up the rear wheels and check the play at 12-6 oclock, I get about .100 or less at the tire edges so there is definetly play. At 3-6 no play at all. The Diff has been rebuilt so I'm assuming this play maybe normal and just yoke play. Struts are new so no issues there.
I'm asking if a couple people could go check same thing and tell me if they at least have a little play at 12-6. THX
Old Jan 30, 2012 | 03:38 PM
fanmanbd's Avatar
fanmanbd
Do a C3 search for differential side yoke end play and you will find a few interesting conversations about this subject.
Old Jan 30, 2012 | 06:42 PM
billcarson's Avatar
billcarson
i to have play at 12 and 6.but my vibration was not from there.most common cause of wobble is an imbalance from your tires.the rule of thumb that was explained to me is that an imbalance far from the rotational center line will cause the most vibration.hence tires #1,bearings not so much.
Old Jan 30, 2012 | 07:24 PM
sstopczy's Avatar
sstopczy
I had some vibrations until I got the wheels balanced. The guy told me the higher profile tires tend to vibrate more when they are out of balance.
Old Jan 30, 2012 | 09:02 PM
Mike Ward's Avatar
Mike Ward
I've never seen a C2/C3 with less than .100 play at 12/6. Look elsewhere.
Old Jan 30, 2012 | 09:53 PM
Steve2147's Avatar
Steve2147
If you are not up to date on the condition of your under carriage, I would start with that. Looseness in the ball joints or other suspension points will not of itself cause a wobble. But it will allow an out of balance tire or a bent wheel to. An out of balance tire in tight suspension will cause a vibration, but that's not what I would call a wobble.
A complete inspection of all ball joints, control arm bushings front and back, wheel bearing looseness is where you start and only takes about 15 minutes. Once you've confirmed everything is tight spin the tires by hand (you'll need to put stands under the rear trailing arms at the wheels to straighten the suspension enough that they will turn freely)one at a time and look for run-out. That could take the form of a bent wheel or squirming tread from a separated cord in the tire. If that all looks good, have them balanced.
Steve g
Old Jan 31, 2012 | 11:48 AM
Surfer69's Avatar
Surfer69
Yeah my suspicion is a bad tire or wheel. The thing is I've had the wheels balanced twice and once while I watched and they should be good. But the vibration is so large that you would think it should be obvious to the naked eye.
I was going to try and have someone drive next to me at that speed and see if they can tell anything but I'm not sure if it would be noticeable.
I'm due for new tires pretty soon so I guess I'll just see what happens after that.
Old Jan 31, 2012 | 12:21 PM
billcarson's Avatar
billcarson
my tires were 10 years old and had plenty of tred left but they could no longer be balanced.
Old Feb 1, 2012 | 02:30 PM
Surfer69's Avatar
Surfer69
One thing I'm thinking about is if the balancer only spins the tires say at 40 mph max, then it would never "see" the out of balance at 55.
Maybe I need to find some kind of super balancer that can spin up to that speed?
Old Feb 1, 2012 | 04:28 PM
LB66383's Avatar
LB66383
Find a shop that has a balancer that also measures road force variance. Even though a wheel/tire is balanced, it can still have variations in the steel belts, roundness in the wheel or tire, etc., that can cause problems on the road.
Old Feb 1, 2012 | 07:25 PM
atp1234's Avatar
atp1234
i've seen this before. try jacking up the car one wheel at a time. Get the tire about a 1/4 inch off the ground put a straight edge on the side of the tire with the same gap and spin the tire. You should find a bad spot with a bubble
Old Jan 21, 2013 | 10:05 AM
Surfer69's Avatar
Surfer69
Update: Finally got my new tires and wobble is gone, so it was bad tires after all since I had the wheels balanced twice before.
Old Jan 21, 2013 | 01:21 PM
billcarson's Avatar
billcarson
glad you got it settled and thanks for posting the result.(helps us to be more accurate in our guessing).
To Wobble at 55 mph, need some help
