wipers stuck under hood?
Old Feb 2, 2012 | 05:03 PM
glarior's Avatar
glarior
Default wipers stuck under hood?
Another new one for me....
Hit a little rain driving this morning and turned the wipers on. Nothing happened and all I hear is a tick tick tick from the relay. I pulled over to investigate and realized they are stuck under the hood. I opened the hood, turned them on then shut the hood. They work perfectly until I want to turn them off... they hit the hood going back to the resting position. To make the fully go down I have to open the hood again.
Suggestions?
Old Feb 3, 2012 | 11:59 AM
glarior's Avatar
glarior
Suggestions?
Old Feb 3, 2012 | 12:08 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I had the same problem about 2 years ago when I replaced my wipers with stock GM wipers. The problem was the new wipers were to tall and they hit my hood too. I finally had to get some low profile wipers (real low). When I finally found some that worked and whenever I had to change my wipers, I only replaced the rubber wipers portions and kept the frame.
Hope this helps...
Old Feb 3, 2012 | 12:21 PM
Shark Racer's Avatar
Shark Racer
Trico Exact-Fit wipers work for me. I put some super-duper triple blade wiper on and ran into the same problem... so I just stick with the Tricos on the 78.
Old Feb 3, 2012 | 01:02 PM
qwank's Avatar
qwank
Trico makes GM's OEM blades. Buy the Tricos and get the OEM style without the GM markup
To wipers stuck under hood?
