What are these wires for ?
Old Feb 2, 2012 | 08:41 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Default What are these wires for ?
Its a 75 coupe with air, for thirty some odd years i have been using the yellow connector as a keyed power source for the radio.
The other two wires are black and gray. Looking at the wiring diagrams and don't see a connector with yellow, black,gray wires on it.
Not really sure what it was for, everything is working ok, just want to find out.
Old Feb 2, 2012 | 09:01 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Its set up correctly for the radio. Grey goes to fuse, black goes to ground. Do you have Doc Rebuild's Dash Harness drawing? Rightside middle.
Old Feb 2, 2012 | 09:15 PM
'75's Avatar
'75
Grey illumination for radio dial
Black ground
Yellow accessory power for radio
Old Feb 2, 2012 | 09:28 PM
BB68Vett's Avatar
BB68Vett
Old Feb 2, 2012 | 09:41 PM
Mod75's Avatar
Mod75
Thank you for jogging my memory, that is the original connector for the radio, all i am using is the yellow wire.
Been so long i forgot about it, think i will use that ground instead of my current one which is attached to the console.
Doc Rebuild's Dash Harness drawing, yes i have seem it.
Thanks for the info
To What are these wires for ?
