Correct spark plug wire date
Old Feb 3, 2012 | 09:42 AM
dd69bb's Avatar
dd69bb
Default Correct spark plug wire date
What would be more a more appropriate spark plug wire set for for a late 69, (November) Q1 69 or Q3 69 which is listed for a 1970 ?
All replies appreciated Thanks.
Old Feb 3, 2012 | 10:25 AM
oldsarge's Avatar
oldsarge
First quarter is March to August, third quarter is Sept to Feb. You would probably want Q3 for your build date.
Old Feb 3, 2012 | 11:50 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Prolonged strike in 1969. Early dates are probably more accurate.
Old Feb 3, 2012 | 12:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by dd69bb
...What would be more a more appropriate spark plug wire set for for a late 69, (November) Q1 69 or Q3 69 which is listed for a 1970 ?...
Have you checked the NCRS Judging Guide?
Old Feb 3, 2012 | 06:43 PM
dd69bb's Avatar
dd69bb
Thanks all , I don't have a Judging Guide, but I will probably go for the early date.
Old Feb 4, 2012 | 04:42 PM
BoeingDriver's Avatar
BoeingDriver
If the trim tag on your Corvette indicates a build in November of 1969, 3rd Qtr 69 plug wires would work perfectly as far as dates are concerned. If you intend to have the car judged there are other considerations, none of which amount to much.
The reproduction braided wires have braiding that is easily distinguished from original. The reason is, the braiding is very tightly wound, unlike the originals that were much more loosely wound. Also, the reproduction wires have shorter boots on the spark plug end which measure approx 2" as opposed to originals that are closer to 2.5"
All of that malarkey is not to say the reproductions are not nice because they are and I appreciate the fact someone produces them. In NCRS and/or Bloomington type judging, reproductions will most likely receive a minor deduction which is no big deal.
Have fun with your car,
Mark
To Correct spark plug wire date
