c3 how hard to pull front clip?
Old Feb 5, 2012 | 10:34 PM
kkperformance's Avatar
kkperformance
Default c3 how hard to pull front clip?
Getting ready to install another engine and TPI in my 74. How much trouble to pull the front clip. Want to freshen up the engine bay. Car is in need of a paint job. On the list. Thanks.
Old Feb 5, 2012 | 10:47 PM
rogman16's Avatar
rogman16
Please don't pull the front clip just for an engine rebuild... You want to try every last resort to fix something on your car "OTHER" than pulling the front clip... I'm in the middle of having pulled mine and a month or two from bonding it back into place... It is a lot of work...
Rogman
Old Feb 9, 2012 | 01:24 PM
ezobens's Avatar
ezobens
Rogman
Well that answers my question... I have a 1 piece front clip from Eckler's that was installed long before I owned the car (69 Coupe).
The left side door, fender and hood seem to fit fine in general but the hood gap and the right side fender to door height and gap is a bit ****-eyed.
Sounds like unless I start busting fiberglass seams open, I'm kinda out of luck?
Elm
Old Feb 9, 2012 | 04:23 PM
7t9l82's Avatar
7t9l82
yes, they don't bolt on
Old Feb 11, 2012 | 08:07 AM
captl27's Avatar
captl27
Good body guys or someone with lots of time can manipulate the lines of a corvette and door spacing with out removal of the front clip.
Old Feb 11, 2012 | 11:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Way more work than you want to do for an engine swap and underhood clean up.
Pulling it isn't the real chore. Reinstalling it correctly is the PITA. The factory used jigs to hold the entire clip in place while the bonding resin cured. You will not have that advantage.
To c3 how hard to pull front clip?
