Smaller Brake Booster for Big Block??
I have consulted with several forum members as to their success using a 7" dual diaphragm booster. My engine vacuum is just under 16" at idle so the 7" booster will cause me to have a slightly heavier pedal than a 9" but I haven't driven the car in so long that power brakes will simply be an improvement anyway.
I have removed all of my information below as to the power brake conversion and am just including the 7" booster stuff that I have found so far.
I think I got my booster from jegs or summit.
Installing a 7” brake booster
The TuffStuff 7" booster and master cylinder combo is about 2" shorter overall and 2” narrower in diameter making it more compact on the firewall and by the engine. (You may need to update your master cylinder lines due to the shorter overall length.)
Tuff Stuff Performance 2122NA
Tuff stuff 2071 master cylinder
Master Cylinder Bore Size1.125 (1 1/8) Corvette style with 9/16 in. and 1/2 in. fitting on driver side.
Booster Diameter (in)7.000. ( 2222na )
• The 7" booster rod is 1/2" shorter from the base of the booster that mounts to the firewall to the tip of the threads on the push rod. This requires the clevis to be longer or some type of threaded rod to be made up. I chose a longer clevis (see below, more info on the clevis at the bottom of this doc.) as the 1/2" is just not that easy to make up when it comes to threaded rods.
7" booster
9" Factory booster
Clevis comparison. I bought a new clevis from Mcmaster carr its forged and makes up the 1/2 I lost on the threaded rod.
Factory clevis
D = 2" from center of the 3/8" pin to the bottom of the threaded end. Threads are part of the flat stamping material.
A = It uses a 3/8" pin
B = The opening between the pin holes is 7/16"s.
It is 1" wide from the side
Threaded female shank of 3/8 x 24
The McMasterCarr clevis
D = 2 1/2" Threads extend out from the clevis body on a 7/8" shank. This gives you 1/2" of additional overall length in threads. (Its forged steel not cast.)
A = 3/8" pin
B = 7/16"
It is 11/16" wide at the side (allows it to articulate on the pedal better).
www.mcmastercarr.com
6071K14
In stock for $7.26
Rod End Type Clevis Rod Ends
Clevis Rod End Type Forged Clevis Rod Ends
Shank Type Female Shank
Shank Thread Type Right Hand Thread
Clevis Material Steel
Finish Plain
Shank Thread Size 3/8"-24
Inside Diameter (A) 3/8"
Clevis (B) 7/16"
Clevis (C) 7/8"
Clevis (D) 2-1/2"
Clevis (E) 7/8"
Clevis (F) 1-5/8"
Specifications Met Society of Automotive Engineers (SAE)
Last edited by mysixtynine; Feb 7, 2012 at 09:35 AM. Reason: had to add the new clevis info
7" booster
9" Factory booster
Factory clevis
A = 3/8" pin
B = 7/16"
6071K14
In stock for $7.26
Finish Plain
Clevis (B) 7/16"
Clevis (C) 7/8"
Clevis (D) 2-1/2"
Clevis (E) 7/8"
Clevis (F) 1-5/8"
Much appreciated.
