roller rockers
Old Feb 7, 2012 | 03:00 AM
dvecustomvettes's Avatar
dvecustomvettes
Default roller rockers
i have a 1969 corvette 350/350hp. motor. it is re-built and balenced with 30 over 11.1/2 to1 forged pistons forged rods and steal crank. the heads are stock but fresh and still have the studs ..i installed a 480 lift comp cam after the break in with new lifters.. now i adjusted the stock rockers and they look like ther alittle sidways to me..i am being told i need to install roller rockers wich i dont mind but now the qwestion is do i need self eligning or no??? anyone no anything about this sorta thing????/
Old Feb 7, 2012 | 06:54 AM
7t9l82's Avatar
7t9l82
don't need self aligning
Old Feb 7, 2012 | 07:31 AM
BKbroiler's Avatar
BKbroiler
Are the pushrod guideplates on your heads?
Old Feb 7, 2012 | 08:10 AM
dvecustomvettes
no just prest in studs
Old Feb 7, 2012 | 08:11 AM
gkull's Avatar
gkull
Did you actually see your pistons before they put them in your motor? Did they have raised domes?
Old Feb 7, 2012 | 08:23 AM
dvecustomvettes
yess the part number from what i remember was something like l2324 or somthing like that and ther are 11.1/2 to1 forged 30 over FOR SHORE
Old Feb 7, 2012 | 08:29 AM
dvecustomvettes
motor was redone to mach its origanal state plus 30 over it is a block and heads maching set to a 69 corvette 350/350hp after i broke the motor in i didnt like that it had no hoppity hop so i took out cam and added the 480 i used one in a dif motor cupple weeks ago and it sounds grait..
Old Feb 7, 2012 | 08:56 AM
BKbroiler's Avatar
BKbroiler
If you don't have Vortec style heads which require self aligning rocker arms, then as far as I know you need pushrod guideplates to keep the rocker centered on the valve stem.
Old Feb 7, 2012 | 09:15 AM
Indiancreek's Avatar
Indiancreek
You running this on pump gas?
Old Feb 7, 2012 | 09:17 AM
billla's Avatar
billla
St. Jude Donor '14
A picture would be worth a thousand words here.
Guideplates aren't required with stock rockers, but if there's an alignment problem then I wonder if the shop enlarged the pushrod holes for some reason...? Regardless, if the stock rockers are seriously cockeyed, putting on roller rockers isn't going to help.
Pressed studs should be replaced with screw-in studs if the heads were hot-tanked.
Old Feb 7, 2012 | 10:46 AM
MelWff's Avatar
MelWff
You went to a higher lift cam with pressed in studs, you need to have the heads converted to screw in studs with pushrod guide plates. Rollers arent going to solve your issue.
Old Feb 7, 2012 | 12:17 PM
BKbroiler's Avatar
BKbroiler
I'm just curious - didn't stock L48 heads have guideplates?
Old Feb 7, 2012 | 12:42 PM
MelWff's Avatar
MelWff
No they did not, guide plates fit under the screwin studs and the 69 L48 had pressed in studs.
Old Feb 7, 2012 | 12:59 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I had studs pull out before from a high lift cam. Lifter popped out of the bore, oil pressure went to 0 and it spun the bearings in the bottom end. We used to drill and pin them but your best bet is to pull the studs, thread the holes and install screw in studs with guide plates.
Old Feb 7, 2012 | 07:27 PM
dvecustomvettes
thanx guys..i called a machine shop that bin building race motors for 30 years when i told them i had a big cam they giggled at me aparently 480 lift is not big at all and dont reqier any mods to the 350hp heads as for the rocker they also told me the rockers do slide to the end when lift is up but straitins out they told me to just install the roller tip 1.5.2's and adgust them like stockers and if they roll off they will fix the motor....well i installed them and they are fine i took the car up to 124 on the hiway and nothing bluw up...lol...so far so good......thanx again
To roller rockers
