Rocker or Lifter Noise ??
Old Feb 9, 2012 | 05:13 PM
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by GMFanatic
The heads are Summit Racing not sure of model number. I do not know anything about pushrods but half of them looked like they are lined up correctly. Haven't checked the ones on the other side.
I missed this, but you'll want to look closely at your pushrod slots. The one and only set of these heads I used where horribly machined - just junk. It's interesting to see Ben call out the Isky adjustable guideplates - that's exactly what we ended up using.
http://forums.corvetteforum.com/1579607685-post12.html
If you look at the pic I posted, you may also want to pull a valve to see if the seat-> bowl transition is as bad as it was on the ones I worked with...
Old Feb 9, 2012 | 07:02 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by billla
63Mako, I agreed with you I just noted that lift alone doesn't drive need for guideplates
I agreed with you too. Just explaining my solution to the OP. I should have quoted post # 10
"But what causes alignment issues and more importantly, how do you fix it."
Old Feb 9, 2012 | 07:05 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Look very carefully at the end of the valve - it may be worn badly. If it is, the valve must be replaced because it is important for the rocker tip to have a perfectly flat surface on the valve tip.
Also look at that pushrod for straightness. It is most likely bent to some degree.
Old Feb 10, 2012 | 12:20 AM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
http://forums.corvetteforum.com/c3-t...ookin-for.html
Wow, those ridges under the exhaust seats are pretty bad. Time for the die grinder and carbides. Almost every head I've ever used gets a few hours touch up work with the die grinder, but those are the worst I've seen.
OP, I'm feeling a bit bad for you. Seems like we've opened the proverbial can of worms for you. Definately pull those heads apart!
Old Feb 10, 2012 | 10:43 AM
ja1724's Avatar
ja1724
St. Jude Donor '12
If it was my car AND I was planning on keeping it I would tear down the entire top end. Pull the cam & lifters check for wear grooves on the lifters, wiped lobes on the cam etc. Bring the heads to a good head/machine shop and have them thoroughly checked/fixed. Basically start over so that I knew the top end was rebuit properly after I was done. Unfortunately you can never trust a previous owners work.
