Anybody using Amsoil?
Old May 13, 2002 | 08:36 PM
467-Ratman's Avatar
467-Ratman
Default Anybody using Amsoil?
Is anyone using Amsoil in their cars and the Amsoil filters? Was told by a friend that its great stuff, expensive though.
Old May 13, 2002 | 09:33 PM
vettedan's Avatar
vettedan
Default Re: Anybody using Amsoil? (467-Ratman)
I use it in my engine and rear end, Great stuff! I use the engine filter as well.
Old May 13, 2002 | 10:16 PM
69er's Avatar
69er
Active Streak: 90 Days
Amsoil all the way.
Engine,filter,trans and rear.
Old May 13, 2002 | 10:24 PM
bence13_33's Avatar
bence13_33
My dad always used Amsoil in the 'Vette. He runs it in his truck every now and again. From what he told me they were one of the original synthetic oil companies back in the day. He also said that it is great stuff. Personally, once I get the big block broken in I'll probably just run Mobil 1 synthetic. Amsoil is pretty pricey.
Old May 14, 2002 | 09:48 AM
Alwyn678's Avatar
Alwyn678
Default Re: Anybody using Amsoil? (bence13_33)
My boss runs it in Both his Porshe's swears by the stuff..I run Dino oil personally....Valvoline
Old May 14, 2002 | 09:58 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Anybody using Amsoil? (Alwyn678)
I just had a long talk with the Amsoil guy at the world of wheels show, ok it was about 3-4 weeks ago now :bb I've also read everything I can find on oil and have come to the decision that Amsoil is the best stuff out there, better than Mobil 1 by far, Red line, Royal purple everything.
The best thing to do is to use Amsoil and then TEST the oil at regular intervals. That way you KNOW how good the oil is and how your engine is wearing. If you just dump the oil you are throwing out the only wear indicator you have for the inside of the engine...
And BTW, Amsoil is supposed to be cheaper if you do it this way. But when you have an $6000 to $8000 engine to protect your going to skimp on oil??? :rolleyes:
Old May 20, 2002 | 01:54 PM
IMQUIK's Avatar
IMQUIK
Since 1992 been running it...NO PROBLEMS :smash:
Buy it Wholesale :cool:
Old May 20, 2002 | 07:51 PM
467-Ratman's Avatar
467-Ratman
Default Re: Anybody using Amsoil? (tshac)
What weight should I go with, was planing on using 20W-50 regular oil, would it be the same to go with Amsoil?
Old May 20, 2002 | 10:24 PM
rainman69's Avatar
rainman69
According to what I have read, you can go approximately 15,000 - 25,000 between changes if you check (test) the oil regularly and use Amsoil. That REALLY brings the price back down to "reasonable." But really, is anything too good for our gals? :cheers:
Old May 21, 2002 | 12:55 AM
4DLuvOfSpeed's Avatar
4DLuvOfSpeed
At the increasing risk of getting banned from this list, since everytime I use a car as an example it hapens to be a ricemobile, here's my experience:
I put Amsoil in both my Mazda Miata's and 323 GTX's trannies (the latter being a 4WD rally car) when I first got them. Both had faulty 2nd gear synchros and shifting from 1st to 2nd was almost impossible sometimes. Amsoil cured BOTH cars. The difference in the GTX was night and day; it went from almost undriveable (I got to the point where I would shift from 1st to 3rd constantly) to being one of the smoothest GTX trannies alive.
Another thing, we did one of those tests like in the infommercials where you put different oils on a spinning wheel attached to an engine and see how much pressure it takes to stop the wheel with each oil. All mineral oils tied at around 4 lbs. Mobil 1 made it to 5 lbs and Amsoil made it to 6 lbs. We also tested some additives loke Slick 50 Prolong and X1-R but that's another long story.
I swear by the stuff.
Cheers,
Javi
To Anybody using Amsoil?
