Oil on Floorboard
Old Feb 10, 2012 | 02:19 AM
Tick's Avatar
Tick
8th Gear
Default Oil on Floorboard
Hi All,
New to the forum and also to Corvette's. I just acquired a 1975 a few weeks back and have started working on the interior. I removed the carpet and noticed that there is something that looks like oil under the padding. Any idea on how it may have gotten there and how to stop it from coming back?
Thanks!
Tick
Old Feb 10, 2012 | 03:45 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Check the capillary tube that goes to the oil pressure gauge, sometimes it leaks oil, mine did.
Old Feb 10, 2012 | 05:13 AM
briaineo's Avatar
briaineo
Changed mine to an electric gauge to prevent that ever happening!
Old Feb 10, 2012 | 05:52 AM
Garys 68's Avatar
Garys 68
The aftermarket tubes and compression fittings dont work well with the oil pressure gauge.
Old Feb 10, 2012 | 06:39 AM
AWilson's Avatar
AWilson
I bought new parts and they seem to work fine. But you have to tighten them pretty good. Electric conversion probably makes more sense.
Old Feb 10, 2012 | 06:59 AM
Paul L's Avatar
Paul L
Oil pressure gauges were electric starting in 1974.
Old Feb 10, 2012 | 07:08 AM
Roco71's Avatar
Roco71
Old Feb 10, 2012 | 07:29 AM
briaineo's Avatar
briaineo
Could it be some sort of sound deadening material / substance
What type gauge does the car have?
Old Feb 10, 2012 | 09:19 AM
Mark Riles's Avatar
Mark Riles
Originally Posted by Tick
Hi All,
Thanks!
Tick
Is there oil coating the outside panels of the foot well? If the engine has been leaking oil onto the under carriage and the seam in the floor panel is loose then it's possible for the oil to seep in through the seam and begin soaking into the padding and carpet.
Old Feb 10, 2012 | 02:59 PM
Tick's Avatar
Tick
8th Gear
I have confirmed that the gauge is not mechanical but electrical. I am going to start the cleanup tonight and hopefully get a better view of what exactly I have going on. The engine does not seem to have a leak now but might have at some point.
Thanks for all the responses, much appreciated.
Old Feb 10, 2012 | 03:07 PM
Tankertoad1's Avatar
Tankertoad1
Could it be a bad heater core that drips antifreeze in on the carpet?
Old Feb 10, 2012 | 04:20 PM
Paul L's Avatar
Paul L
Good point. He did not say what side.
Old Feb 10, 2012 | 11:10 PM
Tick's Avatar
Tick
8th Gear
I'm sorry...it's the passenger side.
Old Feb 11, 2012 | 12:59 PM
my 76 ray's Avatar
my 76 ray
Probably anti-freeze leaking from the heater core. It's still possible that it could habe been fixed in the past. Usually when the heater core leaks you will get condensation on the windshield if you turn on the defrosters.
Old Feb 11, 2012 | 03:45 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
He did say it was oily and under the padding!
Old Feb 11, 2012 | 03:46 PM
Paul L's Avatar
Paul L
Take up a bit with a white paper towel and tell us the color.
Old Feb 11, 2012 | 05:39 PM
Tick's Avatar
Tick
8th Gear
It's dark and ugly. I have started to clean up a bit and it looks like it is coming from near the center column on the passenger side. I think the heater core is the culprit. Once I get the mess cleaned up all the way I will know for sure.
Old Feb 11, 2012 | 05:44 PM
Paul L's Avatar
Paul L
It does sound like the heater core. But it may have been repaired (optimist speaking). If not you should see anti-freeze under the car as well.
Check to see if the heater hoses are still going to the core. Many people will deny the inevitable and just do a bypass.
Old Feb 11, 2012 | 07:31 PM
rponfick's Avatar
rponfick
Just replaced the heater core on my '69, non-AC, BB car and don't want to do it anytime soon again. Not really much fun.
Best of luck. Ralph
To Oil on Floorboard
