Oil Temp. Sensor install??
Old May 13, 2002 | 11:33 PM
72Shark's Avatar
72Shark
Default Oil Temp. Sensor install??
I am installing an oil temperature gauge in my new gauge cluster. Where should I install the sensor?? I noticed a plug in the side of the block near the clutch housing...does this lead to an oil galley?? Or is there one near the filter to tap into?? I hope this can be done easily...any suggestions??? :confused:
Old May 14, 2002 | 01:29 AM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: Oil Temp. Sensor install?? (72Shark)
Not sure about a 72 but on my 81 the oil temp sensor is right above the oil filter. If you have a plug there just remove it and use that hole.
Old May 14, 2002 | 03:37 PM
john's '81 mouse's Avatar
john's '81 mouse
Default Re: Oil Temp. Sensor install?? (C3 Shark Tank)
above the oil filter is normally where the oil pressure sensor is on engines not equipped with oil temp gauge from factory. Oil pressure sensor on an '81 with oil temp gauge, is located on top of block at rear of the intake manifold / lifter valley area. Guess you can install either in either location, but just wanted you to know / understand where these were located from factory.
Old May 14, 2002 | 07:37 PM
Paul L's Avatar
Paul L
This is the one near the oil filter, usually occupied by the pressure sensor as shown. As noted, the stock 1981 set-up places the temp sensor here and the pressure sensor is re-located to the blind plumbing plug on the block near the distributor.
Old May 15, 2002 | 12:12 AM
72Shark's Avatar
72Shark
Thanks guys...especially for the pics! Gonna be a breeze now. :smash:
To Oil Temp. Sensor install??
