caliper ss sleevs
Old Feb 12, 2012 | 09:28 AM
bmprhmpr's Avatar
bmprhmpr
Default caliper ss sleevs
Hi, is it possible to install ss sleevs into oem calipers ( 1978 ) ? I have a press.
Old Feb 12, 2012 | 10:15 AM
dannyman's Avatar
dannyman
Short answer is yes. You will need a shop to bore the calipers.
I would be very surprised if the calipers have not already been sleeved. Disassembly would tell you if required. You may only need to clean and rebuild.
Split the halves and post pictures.
Check this out for visual of the ss sleeves.
http://temp.corvetteforum.net/c3/joe...ructions.shtml
Dan
Old Feb 12, 2012 | 10:21 AM
rdroe's Avatar
rdroe
DC Area Events Coordinator
Also, FWIW, Advanced Auto sells entire calipers that are SS sleeved for $71. They don't know what they have but when you open the box, there is a tag indicating that they have SS sleeves. They are still lip-sealed however and not o-ring. The quality is not so good as the rebuilder left out a .10 o-ring in one of mine between the halves. I took both back, got my $$ and bought Wilwoods.
Old Feb 12, 2012 | 10:24 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I don't think this is a DIY job. Not sure anyone will sell you the sleeves for one thing. You'd also need a bore of the correct size. If you want your original calipers done, try either Muskegon Brake or Lone Star Brake and they'll do them for you.
Mike Ward's Avatar
Mike Ward
Almost impossible to do at home. Either send them out to be done or exchange them for a set.
Old Feb 12, 2012 | 05:21 PM
loup68's Avatar
loup68
Army
The sleeves need to be sealed with some kind of loc-tite sealer. Don't ask me and SSBC how I know this.
To caliper ss sleevs
