Gear Vendors Overdrive
Old Feb 12, 2012 | 05:02 PM
green_79's Avatar
green_79
Default Gear Vendors Overdrive
Has anyone ever installed or know of someone who has installed a Gear Vendors overdrive unit in a C3 Corvette? I am having difficulty trying to fit this unit into my 79.
Thanks for your time.
Old Feb 12, 2012 | 05:39 PM
Mark Riles's Avatar
Mark Riles
If you don't mind an honest opinion the overdrive unit from Gear Vendors in a car like a C3 would be a waste. There are a lot of OD automatic transmissions available. The TH200 bolts right in. The TH350C and the TH700 are also great options not to mention the 4L60 / 80 transmissions. For any purpose there is an OD transmission you can swap in place of your stock unit. The reason I say this is because the GV OD unit is long and heavy. It'll add a lot of weight to your car and instead of just adding a 4th gear and lockup you're adding a ratio to every gear. In essence you are making a 7 speed automatic transmission. While that sounds good, possibly too complicated. You have to manually switch ratios every time you're in a gear if you want to utilize the ratio change and if you're using it as an OD you're wasting that unit on every gear but 3rd. My advice, get a 4 speed automatic with a lockup converter. Less money, roughly same size and weight and much simpler to install. I also for forgot to mention the drive shaft tunnel in a C3 is very tight around the drive shaft. You would certainly have to modify the tunnel in order for the GV OD unit to fit.
Old Feb 12, 2012 | 05:49 PM
3JsVette's Avatar
3JsVette
I have NO personal experience but I'll share what I have seen and heard. The G/V unit is indestructable..........but it's heavy and very hard to package.
I think you have read the same thing in the previous post also.
Old Feb 12, 2012 | 06:27 PM
green_79's Avatar
green_79
Default Thanks
What 4 speed automatic and lockup trans package would you recommend? I am running a 383 stroker with 475 hp and a reinforced TH350. Would this new 4 speed bolt right up without any modifications, ie. Cross member, cooling lines, drive shaft length?
Thanks for your response.
Old Feb 12, 2012 | 07:16 PM
Mark Riles's Avatar
Mark Riles
For a bolt in option the TH200R4 is the best choice. You can re-use everything that is already on your car and the gear ratios closely resemble that of the TH350 so 1 - 3 will be almost the same. Then added 4th and OD. I recommend one from a top rebuilder maybe like Bowtie Overdrives. They sell several high HP applications. They will provide all the installation assistance you need and can set you up with a transmission and converter that best suits your needs.
Old Feb 12, 2012 | 08:12 PM
milo30's Avatar
milo30
The gear venders is pretty tough and could handle more HP than your transmission. They are expensive though. Gear venders should have a list of authorized installers on their website that can install it in your car. If I had already put money into my 350 and bought the gear venders then it would be hard for me to justify the expense of another transmission and the cost of building it up.
The 200r4 is as close to a drop in as you could probably get. Problem is, they are hard to find. I have been looking for one at a reasonable price knowing that it will have to be rebuilt to be able to hold up. There is the 700r4 which is not quite a drop in unit and is easier to find.
Bowtie overdrives is one company that sells both units as well as anything that you are going to need to complete the swap on your car. They have different versions to handle different HP ratings.
Have you contacted Gear venders to make sure that you have the correct part to fit your car?
Old Feb 12, 2012 | 10:13 PM
7t9l82's Avatar
7t9l82
if i remember correctly gear vendors is an updated version of the hone overdrive unit Joel Rosen put in his motion performance corvettes years ago. the g.v unit is an anvil you really have to abuse it to hurt it. a200 overdrive is going to be expensive to handle 475 h.p. i have been thinking of that unit myself.
Old Feb 12, 2012 | 10:51 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I am about to do the same exchange myself to and OD from a th350.. I am going to a 2004r from bowtie..... I called and talked to rich and he set me up with a package with everythign ill need for the swap....for around 2k you can have a nice stage 2 set up and an easy swap...
this comes with trans.TC, lock up system,tv set up . the works..
remember if you use bow tie to make sure and read warranty ... you have to call in with pressure #ers...
Old Feb 12, 2012 | 11:46 PM
lonebull's Avatar
lonebull
I'm assuming you're aware of kaiser buds post just 3 down from yours? Looks like a big mistake to me & I had been considering just such a build. Check it out. Am I mistaken?
Old Feb 13, 2012 | 12:11 AM
76custompaint's Avatar
76custompaint
I in fact do have experience with doing this.. Put one in behind a 700-r4 in a '76 vette. It requires you to ding the transmission tunnel (by ding I mean cut out and weld in a 1/2 box and beat the hell out of it with a 5lb hammer.
Old Feb 13, 2012 | 07:01 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
i put a 700 in mine.. used the bowtie overdrives crossmember and had to have the right side exhaust bent around the pan.. other than that, it wasn't bad to install
oh yeah, you have to have your driveshaft shortened too... 3.875" if memory serves right
Old Apr 12, 2012 | 04:33 PM
7oforgo's Avatar
7oforgo
1st Gear
I looked at the GV for my 70' with TH400 and spoke to the company. There have been very few installed in automatic C3's acconding to GV. They told me I would need to cut the tunnel and the drive shaft would be almost on the end of being too short. I'm ok with mods and extra cost if it works well. Then I took a hard look at the gear ratios thru all the gears vs a 700R4. I went with the 700R4, the gearing is much better for accelleration in 1st and 2nd, and the over drive gear is much taller so cruising at 70mph is nice at around 2300prm with 3:70's in the rear. Another drawback with GV is you only use the unit for D.O. because the manual shifting is a hassle, shifting 1st in under,1st over, then shift back to under and trans to 2nd.... 2nd over
The 700R4 fits really nice, no cutting. It really gave my car a kick in the nads.
To Gear Vendors Overdrive
