blowing oil
Old Feb 15, 2012 | 04:46 PM
calvette 11's Avatar
calvette 11
Default blowing oil
I need some advise.
I have a 76 vette with a big block in it.I have started to have oil blowing out the valve cover breathers.I checked to compression and all are over 200.What could be the problem?
Old Feb 15, 2012 | 04:49 PM
Mark Riles's Avatar
Mark Riles
Originally Posted by calvette 11
I need some advise.
Do you have a functioning PCV system?
Old Feb 15, 2012 | 05:08 PM
calvette 11
Default oil
I n the driver side valve cover.When I pull it out I see a small oil mist
Old Feb 15, 2012 | 05:18 PM
MelWff's Avatar
MelWff
In the driver side valve cover you have a PCV and no breather? Does the passenger side have a breather?
Old Feb 15, 2012 | 06:22 PM
calvette 11
Default oil
pcv in driver side ,and a push in breather in the passenger side
Old Feb 15, 2012 | 07:18 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Do you have baffles in the valvecover under the PCV and breather holes? Many aftermarket covers have insufficiant or no baffling. High volume oil pumps compound the problem.
Old Feb 15, 2012 | 08:48 PM
Mark Riles's Avatar
Mark Riles
Pull the PCV valve and shake it to see if it rattles. Can't hurt to squirt some brake cleaner through it to help clear out any gunk. Also pull the filter and inspect it as they tend to soak up oil quickly when there is a problem with the ventilation.
Old Feb 15, 2012 | 08:52 PM
calvette 11
Default oil
There are baffles under each and I put steel wool in each hole,to slow the flow.
Old Feb 16, 2012 | 12:20 AM
BLOCKMAN's Avatar
BLOCKMAN
You need a complete PVC get rid of the breather and hook into the bottom or the side of the air cleaner like an OEM style.
Compression test is not as accurate as a Leak down test at TDC.
I have seen new builds with good compression but leak down up to 40%
Old Feb 16, 2012 | 05:22 AM
calvette 11
Default oil
What is the correct way to do a leak down test? And what will it tell me
Old Feb 16, 2012 | 07:30 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I think the guys are right with looking at the PCV system.
Old Feb 16, 2012 | 08:05 AM
metro's Avatar
metro
A leakdown test will give you comparative readings for each cylinder indicating the ability of the cylinder to "hold" compression. It's not a difficult test to perform but it does take some time.
Here is an article from Car Craft magazine
http://www.carcraft.com/techarticles...r/viewall.html
Old Feb 16, 2012 | 05:53 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
when I fired up my BB, I had a problem of crankcase pressure building up and blowing oil out also,
finally found the aftermarket pvc gromment, was sealing up tight, not allowing the PCV to do its job. modiified the gromment to ensure it did not seal up closed, problem solved.
To blowing oil
