Painting T-Tops
Old May 14, 2002 | 11:05 AM
SteveA's Avatar
SteveA
Default Painting T-Tops
As I'm prepping the t-tops (1979) for paint, I'm wondering if I should attempt to remove the metal trim/molding/rail (or whatever you call it) that wraps around the front and outside edge, or just sand up to it and prime/paint. At first I thought I'de leave it on. I'm concerned about chipping the new paint when re-installing as it is a tight fit. Any experiences? At a quick look, I'm not sure how to get if off without damaging the top anyway. Thanks in advance.
Old May 14, 2002 | 11:23 AM
Fleetwood's Avatar
Fleetwood
Default Re: Painting T-Tops (SteveA)
My advice to you would be to leave it on.Removing this trim piece is a real PITA,& as you mentioned putting it back will just damage your new paint.Make sure you clean & polish the trim before you paint the tops,that way you won't scuff your new paint finish.Then just mask it off.
