Power windows on my 75
Old Feb 18, 2012 | 12:32 PM
Ralphbf's Avatar
Ralphbf
Default Power windows on my 75
Well it looks like it's time to address issues with my power windows.
Passenger's side goes up slow and stalls at the top.
Driver's side goes 1/2 way up and then you can hear the teeth skipping.
I ordered new, well I don't know what it's called but it has the teeth and not the gear.
Anyway I need to work the doors over. New rollers, clean the tracks and all that that goes with it.
Problem I've never done this stuff before.
Where should I start?
Ralph
Old Feb 18, 2012 | 03:56 PM
1986coupe's Avatar
1986coupe
Start by reading as much as you can. This will help you to understand how the system works and prevent you from breaking anything accidentally. Make sure you have all of the tools that are needed.
Once you have everything and some confidence start by taking the door panels off...carefully. Only work on one door at a time...that way if you have a problem you have the other to look at as a reference.
Some issues can be fixed by simply cleaning electrical connections. ONce you can access everything look at all of the electrical connections to see how they are. If there is corrosion clean the contacts.
The rest I will leave for those with specific experience. I have had my door panels off on my 1976 and looked at everything but haven't done the actual work.
Old Feb 18, 2012 | 08:19 PM
Bills17n72's Avatar
Bills17n72
well if you need a power window motor for the passenger side ,I have one out of a 79 ,$35.
Old Feb 19, 2012 | 10:39 AM
Peterbuilt's Avatar
Peterbuilt
Default This might help...
http://www.corvettemagazine.com/body...regulator.html
Old Feb 19, 2012 | 11:53 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Ralphbf
...Where should I start?...
Start by purchasing the assembly instruction manual (AIM) and looking over the diagrams of the factory power window installation.
The GM chassis service manual might also be helpful.
Old Feb 19, 2012 | 02:41 PM
Ralphbf's Avatar
Ralphbf
Thanks thanks this what I was looking for.
I have a manual but I like these type of write ups as a supplement.
Ralph
Old Feb 20, 2012 | 11:48 AM
ted13b's Avatar
ted13b
I just went thru this. It's time consuming but not too bad. It's amazing the difference that cleaning and regreasing everything can make. This is also an excellent time to de-squeak and un-rattleify everything. I found the buhings on my lock rods were shot and the metal clips were bent so everything rattled inside. Also the wires to the regulator would slap inside the door when it was slammed. A couple of hours of work and it sounds like a new car when I slam the doors.
Old Feb 20, 2012 | 05:06 PM
75 Vette's Avatar
75 Vette
Regarding the passenger side: check the glass alignment of the window. The adjustment is on top of the door (front and rear) after you remove the door panel. If adjusted wrong it might be binding near the top of the run.
Old Feb 20, 2012 | 08:08 PM
johnt365's Avatar
johnt365
I think you are talking about one of the $29 teeth repair kits. I installed one myself and it works great. However, it was a challenge to install. The hardest part for me was actually drilling the holes for it. I was able to drill one of the three holes for it myself with a hand held drill. I couldn't get the others even with a new carbide bit.
I took it to a guy who owned a motorcycle/small engine shop to see if he could help. Nothing. He referred me to a machine shop next door and they had a drill press and clamps and still broke a bit trying to do it. But they were able to do it.
They put the regulator on a Rockwell hardness tester and I sure wish I could remember the reading to tell you. All I am saying is if you have a hard time drilling the holes you are not alone.
Best regards
Old Feb 21, 2012 | 01:00 AM
Korevette's Avatar
Korevette
Those 'sissor' arms are under tension from a spring assist to lift the side glass which in turn helps the 'power window' motor to left and decend the window by the tightly wound spring.
We would seperate the motor from the mounting frame but understood the 'energy' within that spring.
If seperating the motor, please secure those sissor arms as they will physically spring into action once the motor drive gear has been seperated from the half circle 'teeth' gear on the arms. I did not loose a finger tip but did get a 'pinch' blister.
The mechanism is basic. Cleanliness is key, replacement of worn pivot points makes the unit tighter. Study the operation and you will see results.
Good luck.
Old Feb 22, 2012 | 03:03 AM
Ralphbf's Avatar
Ralphbf
I contacted Ecklers and simply asked them for a list of all the parts they carry for the windows, 75 coupe.
After 3 letters and an assurance that they just couldn't do that, I decided to use someone else.
They want me to take the windows apart make a list of what I needed, send it to them, wait for the parts, and then put the windows back together.
I know I'm a simple guy.
I want to replace ALL the stuff so it will be like new again.
I would think this would of been an easy sale.
Am I missing something here.
Sorry for the rant, but really.
Where have you had good luck getting window parts?
Ralph
Old Apr 10, 2012 | 11:42 AM
Cruisin Davey G's Avatar
Cruisin Davey G
Ralph
Ralph:
I know I'm chiming in here late, so, did you ever get your power window system re-done?
Old Apr 10, 2012 | 04:59 PM
Ralphbf's Avatar
Ralphbf
Not yet.
Willcox has been jerking me around for 3 months on 4 screws so I refuse to do business with then until that's taken care of and Ecklers doesn't know what I need.
I would think Ecklers would look at the Willcox web site to get a a kit together.
Ralph
Old Apr 10, 2012 | 06:26 PM
Cruisin Davey G
Ralph:
Sorry to hear bout you & Wilcox. I've always had good success with them. They're pretty good. I never deal with Ecklers.
To get all of my stuff for the window job, I went to a couple of places.
Corvette America in Pa. & RIK's in North Carolina. They're pretty good at getting what you want. Corvette Central too.
I see your from California
Sorry, but most of the places I deal with are here on the east side of the country. Don't know too many out your way.
Well, Good Luck with your Window Situation.
"Cruisin Davey G !"
Old Apr 10, 2012 | 08:12 PM
dinodon51's Avatar
dinodon51
I just redid my 1980 windows and encountered similar problems. The windows put a real pull on the electrical system. In working on them, I had let my battery go low and it required recharging to give me full lift. Also, I found that by angling the bottom of the front channel out and the top in as far as possible, the least resistance was created for the lifts. Additionally, I junked the two top clips on the front rubber which were creating both resistance against the lift and making window alignment even more critical than it could be. Hope this helps.
Old Apr 10, 2012 | 08:54 PM
Ralphbf's Avatar
Ralphbf
I wanted to replace what ever I could when I disabled the window so I would never have to do it again.
How many rollers are there anyway?
Ralph
Old Apr 10, 2012 | 09:07 PM
Cruisin Davey G
Ralph
RIK's Corvette Usually Sells the Window Rollers in Kit Form. I Also Believe they do the same for rebuilding the Regulators.
Here's a Link to their Website
http://www.riksvet.com/
They got a real good on-line Catalog in PDF Form.
Check Em Out !
"Cruisin Davey G !"
To Power windows on my 75
