what sensors are these ??
Old Feb 19, 2012 | 02:49 PM
Mikeylikesit79's Avatar
Mikeylikesit79
Cruising
Default what sensors are these ??
first sensor is located on passenger side engine manifold between ehaust ports, between #7 and #8 plug -2 prongs 1 black wiire 1 blue wire??
which wire should be where?
second os on drivers side between #1 and #2 plug 1 prong no wire attached
if its the temp sensor should there be a green wire??
Old Feb 19, 2012 | 03:19 PM
scottyp99's Avatar
scottyp99
How could it be on the exhaust manifold between 7 and 8? You must mean 6 and 8, right? Same with 1 and 2, you mean 1 and 3, right?
I've never seen any kind of sensor on the actual exhaust manifold on a car that old, I have no idea what that could be, maybe it's not the original motor. The one on the driver's side is most likely the sensor for the coolant temp gauge, should be a dark green wire going to it.
Keep the shiny side up!
Scott
Old Feb 19, 2012 | 03:26 PM
thegazman's Avatar
thegazman
Default thegazman
On my 79 L-82 the sensor in the right head between the 6 and 8 cylinders is for the auxilary electric cooling fan and the sensor in the head between the 1 and 3 cylinders is the temperature gauge sensor. FYI the cylinders on the driver's side (left) of your engine are numbered 1-3-5-7 and on the passenger (right side) are numbered 2-4-6-8.
Old Feb 19, 2012 | 03:27 PM
Mikeylikesit79
Cruising
yes i do believe its not the original motor which is my issue! thanks for the response ill keep trying to figure it out
Old Feb 19, 2012 | 03:31 PM
Mikeylikesit79
Cruising
thanks that is what i meant! sounds like you solved the mystery!
i am loosing my mind the previous owner replaced the engine and the wiring is a mess plus they spraypainted the engine compartment along with alot of the wiring so most all the wires are black and ?? Thanks for the info
To what sensors are these ??
