Solid Conversion U-joint (1310-1330) ???
Old Feb 19, 2012 | 09:21 PM
OzzyTom's Avatar
OzzyTom
Default Solid Conversion U-joint (1310-1330) ???
I'm looking for a conversion U-joint from #1310 to #1330.
I currently have a greasable U-joint fitted, but would like a solid U-joint if there is one available.
Does anyone know of manufacturer and part number of a suitable solid conversion U-joint?
I found this Spicer item, part number (IR-S5134X) but can't determine for sure if it is solid.... looks solid, but there is no mention in advert.
http://www.ironrockoffroad.com/Merch...Code=IR-S5134X
Old Feb 20, 2012 | 03:33 AM
tracdogg2's Avatar
tracdogg2
Unfortunately there is no such joint. The solid u-joints use a different design on the main body.
Mike
Old Feb 20, 2012 | 06:48 AM
OzzyTom's Avatar
OzzyTom
OK.... if there's no solid conversion U-joint, then my option is to either convert the diff yoke to 1330, or convert the driveshaft to 1310.
Which size is considered stronger.... 1310 or 1330?
The 1330 has same size cups, but has slightly longer arms.
From what I've read, the 1310's were fitted to driveshafts on manual gearbox models, whilst the 1330 was fitted to those cars with auto trans.
Would I be right in deducing that the 1310's can cope with greater torque load due to the shorter arm length?
Old Feb 20, 2012 | 12:44 PM
iokepakai's Avatar
iokepakai
Denny's Driveshaft's has that ujoint.They have a website..Bought my soild ujoints from them....Aloha's
Old Feb 20, 2012 | 12:49 PM
MN80Vette's Avatar
MN80Vette
I bought a set of those u-joint from Paul at Northside Corvette last year:
Northside Corvette/
Old Feb 20, 2012 | 08:50 PM
alswagg's Avatar
alswagg
http://eastcoastgearsupply.com/images/F58780.jpg
http://eastcoastgearsupply.com/i-135...er-joints.html
Click on the link for Yukon Gear super joints. These are chromoly needless ujoints, hands down the strongest U joint for comparable size. I have been running these on my front axle 4x4 for years after breaking every Dana joint i tried. Dana joints are extreamly stong though. I cant imagine any Corvette having enough torque that would need these, but if you want some solid joints, here they are. Al
Old Feb 21, 2012 | 12:27 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Not solid.
http://eastcoastgearsupply.com/i-135...n-u-joint.html
Old Feb 21, 2012 | 06:01 PM
iokepakai's Avatar
iokepakai
Excuse ,meant to say non greaseable ujoint (no zerk) instead of solid.
Old Feb 21, 2012 | 06:04 PM
tracdogg2's Avatar
tracdogg2
Apples to apples (precision joints) the 1310 is stronger. With the spicer 5-1310X to 5-1330X they are the same strength.
Mike
Old May 24, 2012 | 08:09 AM
Vettekid1992's Avatar
Vettekid1992
http://www.summitracing.com/parts/MOG-253/
To Solid Conversion U-joint (1310-1330) ???
