77 electrial issues
2nd I can't get the washers to work new pump check the wires with ohm meter no brakes does the yellow wire on the pump is hot with key on diagram shows it joined with Bat wire on dist the Dk Blue does it switch to ground? getting crossed eyed following.
Thanks for any help.....
