electrical light issues
Old Feb 21, 2012 | 07:08 AM
KevinG's Avatar
KevinG
Default electrical light issues
During my restoration on my '69 4spd, all harnesses were replaced during the process. Here is the issues I am running into:
-parking lights won't light up when pulling halfway on new headlight switch
-while pressing brake pedal - right brake light bulb only lights up single filament, while left side lights up like it should
-left reverse light stays lit while car is turned on, right side not lit up
-Flashers WILL work
-Turn signals WILL work also
I have the grounds of the rear lamps attached to the screws holding the tail lamp housings to the body, dash ground is attached at the birdcage.
Can anyone try to help me out in what is going wrong here?
Thanks!
Old Feb 21, 2012 | 09:53 AM
my 76 ray's Avatar
my 76 ray
Trouble shoot one thing at a time.
If it isn't lighting up when it should, check to see if there is power coming in. Check the bulb to make sure it is good and make sure it has a good ground.
If it is lighting up when it shouldn't, then power is somehow getting to it through a short circuit or bad switch.
A multimeter or a test light will be very helpful.
Old Feb 22, 2012 | 09:44 AM
KevinG's Avatar
KevinG
I'm thinking one of the fuses has blown or I need to find a better ground to the rear light harnesses?
Old Feb 22, 2012 | 09:59 AM
wombvette's Avatar
wombvette
Hard to say when we dont know what year it is.
Old Feb 22, 2012 | 01:02 PM
KevinG's Avatar
KevinG
Sorry, its a '69 4 speed
To electrical light issues
