Quick question on my 80 build project.
Old Feb 22, 2012 | 07:56 PM
LongIsland C3's Avatar
LongIsland C3
Default Quick question on my 80 build project.
The new small block going into the car is going to be just north of 500hp.
In regard to the stall converter (TH350) I hear contrasting opinions from different people. Since I lie awake at night thinking of new and creative ways to explain to my wife why I HAVE to build this car I was wondering,doesn't the rear axle ratio factor in which converter I should use? I know a buddy of mine with a similar drivetrain in a early Chevelle uses a 2500 stall with 4/11 gears. I have a non L-82 automatic C3. Were there different ratios? Thank's...Vince
Old Feb 22, 2012 | 09:24 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Gear ratio is one of many things that you will need to consider when you choose the converter.
The higher your rear gear is (lower numerically) the looser your converter will act around town.
You can still run a fairly high stall converter even with a highway gear, as long as you are prepared for the way its going to behave. It will slip quite a bit at low speeds, and also generate more heat than a tighter converter.
Your car has a 3.07 gear if its original.
Old Feb 23, 2012 | 09:33 AM
nonracer's Avatar
nonracer
As Driveshaft said gear ratio is just 1 of many things you have to factor in, vehicle weight,tire diameter,gear ratio,trans, cam duration, etc,etc, picking the right converter will effect drivabilty quite a bit , since you seem to know the hp of the engine Im guessing its been on the dyno that will give you the actual rpm range of the engine ( which will help you pick out the correct rear gear also) after you have all the info call some converter manufactures and see what they say. Being a street car they will probably set you up a little tight ( lower stall speed) than what is optimal ( track use) but it will be a lot closer than just picking one out of a catalog. I would get one built custom for your application even though the cost will be more.
Old Feb 23, 2012 | 10:41 AM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Solve this issue, everything else will fall into place. Just my opinion. If my wife knew what I spend on Corvette builds, she would insist on a new Cadillac. Every year. She drives a new Ford Fusion for a reason.
Old Feb 23, 2012 | 06:00 PM
LongIsland C3
Thank's for pointing me in the right direction guys, much appreciated!
Old Feb 23, 2012 | 08:45 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It also makes a big difference if your 500HP motor is 350CI or 406+ci .
Old Feb 24, 2012 | 01:46 PM
Gale Banks 80''s Avatar
Gale Banks 80'
You may also consider a 4 speed Auto Trans. A lower 1st Gear will do some of the same things as a Higher Stall Converter and You also get a Overdrive for the Hwy. This is one of the first things I did to my 80 back in the 80's and it made a big diffence.
Old Feb 24, 2012 | 06:43 PM
LongIsland C3
You know, I've been wanting to pull the trigger regarding that trans for the past month. The only reason I hesitated was that my engine build got a little crazy. Anyway, taking the ferry at 6am tomorrow morning to Connecticut to look at a trans.
Thank's again guys, I've never been on a forum that's been this accurate, you guys are on the ball!
To Quick question on my 80 build project.
