LS1 fuel pump?
Old Mar 1, 2012 | 11:26 AM
glarior's Avatar
glarior
Default LS1 fuel pump?
LS1 into 80 vette. Used a acdelco EP241 but only getting 35-40psi on the rail. I need more because having fuel issues.
For those who did the LS1 conversion what pump did you go with?
I used the 82'vette fuel assembly and then replaced the pump with ep241... what will replace the ep241?
Old Mar 1, 2012 | 05:16 PM
aussiejohn's Avatar
aussiejohn
glarior,
I don't know anything about the ep241, but I do know that the 1982 ( and 1984 ) Corvette had throttle body injection, TBI, and these use much less fuel pressure than EFI, even though a TBI is a form of EFI. ( It is an electrically powered fuel injector! ) I think that TBI uses around 12 psi, but modern EFI engines need 45 to 55 psi. So 35-40 is too low for what you need.
Good luck.
Regards from Down Under.
aussiejohn
Old Mar 1, 2012 | 06:02 PM
Garys 68's Avatar
Garys 68
Ebay or google walbro 255lph in-tank or in-line pump. I've used both. I'm using an inline on the corvette.
Old Mar 1, 2012 | 06:26 PM
72LS1Vette's Avatar
72LS1Vette
I'm pretty sure that's the one that I'm using also - the inline version.
Rick B.
Old Mar 3, 2012 | 11:55 PM
mark6669's Avatar
mark6669
I have walpro 255LPH intank pump in my 69
Mark
To LS1 fuel pump?
