What size thread is a 1971 pinion nut.
Old Mar 4, 2012 | 04:42 PM
Jackk's Avatar
Jackk
Default What size thread is a 1971 pinion nut.
I am replacing my leaking pinion seal on my 71 BB. Got everything apart. The pinion nut was real tight all the way off. I know I should put on a new nut but I will lose my reference mark if I do. I would like to just run a tap into the nut to clean up the threads. It looks like a 7/8/14 to me. Anybody know for sure?
Thanks Jackhttp://images.ibsrv.net/ibsrv/res/src:forums.corvetteforum.com/get/images/smilies/Cdnsmilie.gif
Old Mar 4, 2012 | 06:19 PM
qtlow's Avatar
qtlow
Default No tap.
The pinion nut is a locking nut and is supposed to be real tight all the way on and all the way off.
Some people suggest replacing the nut anytime it's removed but I think that's a little extreme.
Just reuse the nut and don't use a tap on it.
Old Mar 5, 2012 | 11:35 AM
Jackk's Avatar
Jackk
I won't be able to use the original nut. It was soooo tight coming off that it tore the threads up. The threads on the pinion are fine. Now the issue of course is getting the correct torque with a new nut.
Jack:
Old Mar 5, 2012 | 11:45 AM
pws69's Avatar
pws69
Jack:
That's because the last person to put it on stripped it! This happens a lot with this type of nut - people don't pay enough attention and keep tightening when the nut is completely on.
Old Mar 6, 2012 | 09:51 AM
69 Chevy's Avatar
69 Chevy
If they did that, they would collapse the crush sleeve and the ring & pinion would not be aligned correctly.
16 thread pitch reading on my gauge for a spare pinion out of my '69. So my guess is 7/8" by 16 tpi.
Old Mar 6, 2012 | 11:34 AM
Jackk's Avatar
Jackk
[QUOTE=69 Chevy;1580200350]If they did that, they would collapse the crush sleeve and the ring & pinion would not be aligned correctly.
16 thread pitch reading on my gauge for a spare pinion out of my '69. So my guess is 7/8" by 16 tpi.[/QUOTE
I think you are right, when I compare my 7/8 14 with the pinion, it is not not quite fine enough. Looking at the thread I don't think it is wise to reuse the old nut at all. Any way to approximate the original torque using a new nut? I am thinking that if I line up the helix of the threads on the old nut to the new one, and transfer the reference mark to the new one I should be close enough. Comments?
Old Mar 8, 2012 | 10:18 AM
69 Chevy's Avatar
69 Chevy
I'm no differential expert by any means. But I wouldn't use a torque reading when replacing that companion flange nut. I'd try to transfer your reference mark from the old nut. Although using a dial indicator on the inner end of the pinion would be best. Put some sealer like Permatex #2 on the companion flange splines...a leak there is often mistaken for a bad seal. Lock the flange from moving and tighten your nut. Take it glacially slow when approaching the number of revolutions you counted when removing the old nut. Stop when the dial indicator moves even the tiniest amount. That will bring you up snug to the crush sleeve and the relation of the pinion to the ring gear will not be compromised.
You did say you had 'everything apart.'
Old Mar 9, 2012 | 12:56 PM
Jackk's Avatar
Jackk
I think my comment having everything apart was confusing. I am doing this with the diff. still in the car. My plan is to transfer my reference mark to the new nut and align the two, no torque wrench. I am going to use permatex on the spline and under the washer. I thought that the pinion position relative to the crown was controlled by shims and that the crush sleeve controlled the bearing preload only. Have I got it wrong. Wouldn't be the first time.
To What size thread is a 1971 pinion nut.
