My 74 bone stock 454 recently started running bad. Blowing out alot of soot on start up. Coughs and sputters. Backfires on occasion.
Anyone have an idea where I can start looking?
TIA.
I don't know. I'm in Texas and have been driving it over the winter when weather permits.
This started out barely noticeable and has gotten progressively worse.
Thanks for your reply.
If the choke flap is "closing" properly when cold, prior to starting, make sure the choke pull off is opening the flap some after the engine starts.
I have a Holley Street Avenger and had that trouble. Took me a while to locate the pull off adjustment but once I did it was an easy adjustment, and solved the problem.
Remove the air cleaner and right after it starts, jump around an slightly open the flap with your hand and see if that helps.
My buddy just finished a 69 427 roadster with similar symptoms. Changed out all the valve springs, there were 3 broken ones. This is not a fun job with.power brakes. Because this Vette sat for long periods without being started the compressed springs took a set and failed when it was started after years of neglect.
Sounds to me like your choke pull off vacuum canister has failed. As soon as the cold engine starts, it should pull open the choke just a little bit- maybe 1/4". If that's not happening, check the pulloff motor with a vacuum gauge. It's on the front right side of your Quadrajet.
Thank you for the reply. Gives me something else to look at.
