Shock Choices?
Old Mar 10, 2012 | 06:25 PM
LongIsland C3's Avatar
LongIsland C3
Default Shock Choices?
Hey Guys, in leafing through past forums I see that many of you use a different shock set front to rear. I'm running an '80 with a modified small block. not going to be racing, looking for a good all around streetable combo. Thank's
Old Mar 11, 2012 | 05:15 PM
MelWff's Avatar
MelWff
seems like the best reasonably priced shock these days is a Bilstein. I havent noticed anybody using different shocks front versus rear.
Old Mar 11, 2012 | 05:30 PM
Tim H's Avatar
Tim H
If you want a nice street ride i went to Autozone and for $25 a piece I got Gabriell ultras, they are black and ride great.
Old Mar 11, 2012 | 06:00 PM
htown81vette's Avatar
htown81vette
I went with Bilstein sports all around, couldn't be more happy with the ride quality.
Old Mar 11, 2012 | 07:15 PM
Ironcross's Avatar
Ironcross
You cant get any better shock than the selection Monroe has to offer and available at most local parts stores....
Old Mar 12, 2012 | 07:07 AM
jb78L-82's Avatar
jb78L-82
I have used different shocks either of the same make or different shock manufacturers since 1983 on my C3 since I have found that the completely different designs of the C3 suspension required very different shock damping for the ultimate shock damping. Originally, I used koni oil shocks in the front with the 550 springs and KYB gas a just with the f 41 7 leaf steel spring. In 1985, I installed a 360 mono spring with the same setup but found that the KYB's were way too bouncy with the composite. I even replaced the rear KYBs under warranty in the 90s to try and eliminate the bouncy ride. In the early 2000s I switched to Bilstein heavy duties all around which were a BIG improvement in ride and handling but still felt that the HDs in the rear with an360 mono spring were too soft and switched to Bilstein Sports (30% stiffer than the HDs) and they are perfect now-ride great, handle great-with Bilstein HDs in the front. The composite spring requires much more damping than steel coils or the rear leaf spring. Hope that helps!
Old Mar 12, 2012 | 08:32 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Bilstein HD's all around on my Gymkhana-equipped '80. Big improvement.
Old Mar 12, 2012 | 08:38 AM
Alwyn678's Avatar
Alwyn678
Sounds like Bilstein sports are favored here. How big a job is it to change the shocks?
Old Mar 12, 2012 | 08:40 AM
htown81vette
Not too bad, a wee bit harder than your average car, but do-able. Maybe 2 hrs.
Old Mar 12, 2012 | 08:42 AM
Alwyn678's Avatar
Alwyn678
Bilstein BST HEAVY DUTY $400 bucks for 4 is Not too cheap, where I am looking.
Where can I find the best price?
Old Mar 12, 2012 | 08:56 AM
htown81vette
Try ebay. They are worth every penny though (in my opinion). You get what you pay for.
Old Mar 12, 2012 | 09:01 AM
Alwyn678's Avatar
Alwyn678
thanks for ebay tip. Drop shipped from Bilstein is also a bit cheaper as well
Old Mar 12, 2012 | 09:11 AM
mikep3's Avatar
mikep3
Try the internet, I goolged and got sevaral places at $80.
Our supporting vendors have simialar pricing. Corvette America was cheaper than Summitt.
Old Mar 12, 2012 | 10:16 AM
DRIVESHAFT's Avatar
DRIVESHAFT
When I bought some Bilsteins last year, the best price I found with shipping included was at Tire Rack.
They also happen to be a forum supporting vendor.
Old Mar 12, 2012 | 01:17 PM
Tim H's Avatar
Tim H
There you go shell it out!
Old Mar 12, 2012 | 01:59 PM
htown81vette
Thats it man. Put it all on the plastic, you can always just file bankruptcy later*
(*from Drag Racing Secrets Vol. III)
Old Mar 12, 2012 | 04:52 PM
glackore's Avatar
glackore
Well, I am partial to Koni's. They do cost some $$$ but I really like the adjustability so you can dial in your ride.
To Shock Choices?
Old Mar 12, 2012 | 05:46 PM
Tim H's Avatar
Tim H
I liked Konis and bought some, they came in white and it wasnt a month and they were grimy brown.
Old Mar 12, 2012 | 06:11 PM
LongIsland C3
Bilstein HD's it is! Thank's Guys.
Old Mar 13, 2012 | 12:05 AM
Ironcross's Avatar
Ironcross
the shocks say adjustable, is there some trick to them or is it by magic? Never could figure that feature out...
