My blower motor is operating on high speed. I can live with but it does not stay on. It is very erratic, it will go from high speed to off and back to high. I dont know if it is the switch ont console or the resister on thew blower. Howe can I chech it, and where is the resister located?
and how do I get at it ??
If it only works on high speeds then you need to replace the resistor. If the high speed is inconsitent after the change then you should troubleshoot the switch.
Thanks for the help,
I just ordered the resistor and the console switch. I will try the resistor first and if that works I will have a new console switch if that ever goes.
