Have a badly stuck lifter so I am in the process of pulling the cam so I can try to knock the offender down. I pulled everything apart, including the fule pump and rod and the cam slid out 3 lobes and then hangs on something. The lifter is stuck up high, and the bearing slides by ok. After I get the thing out the three lobes it seems to hit something metal and hang there. Any thoughts or ideas about how to finish getting it out or thoughts about what I might have missed would would be a great help.
Did you pull out all of the other lifters first?
How are you pulling it out?
It sounds like once you cleared the first bearing that the shaft just dropped down and is now hitting the wall behind the next bearing.
They make a handle that you can bolt to the end of the camshaft to help lift it up.
It has to come out straight which takes a lot of pressure to keep the back end from dropping down.
I assume the engine is still in the car. If not, roll it over on the stand, take the oil pan off. You can access the shaft from underneath which will make it easier to slide it out.
Good luck.
BTW - that lifter sounds like it has mushroomed at the bottom. May have taken out the cam lobe in the process.
Pulled all the other lifters, Have a bolt in the cam and am pulling straight forward. Good assumption, engin is still in car. I dropped oikl pan loose, am going to take off to see if I can see anything through the bottom. The shaft actually seems to make it to the next set of bearings as it sits straigth and spins easy. That is where it seems to get stuck.Have lifters,a new cam and timing gears and chain in the box waiting to go, not sure what has this hung up.
John
Hey John,
Try mounting the upper cam gear to the stuck cam.
Use that to pull the cam out as you can get more leverage lifting it up.
With 4 bearings to go through it is a little tricky keeping it straight so it can come out.
I'll be interested to hear how this ends up.
Good luck
Dennis
If this was a stroker I would be looking at rod and crank clearance with the cam lobes. That would just require turning the crank a little to let lobe past.
But would I be able to move it out at all in that case?
As to the cam bearing stuck to the cam journal - that is a possibility. If it spun and came completely out of the cam bearing hole, it should knock off at the next bearing it hits
But that would not be good news even if you can get it off the cam and the cam out.
What will hold the replacement bearing back in place without some machining? Now you are talking about pulling the engine and taking it to a machine shop.
To see if that is the case you should be able to see the cam thru the lifter bore holes. Look to see if you can see the cam journals thru there.
I still think that the cam has dropped down once it cleared the first bearing and you need to get it back up and level all the way to get it to then clear the next bearing. Same for the next one.
See if someone has a flexible lighted bore scope you can use and feed it down thru the lifter bore hole.
If you can - take some pics & post them here. Lots of light thru the lifter bore holes and the oil drain back holes in the lifter valley.
Quick update- I dropped the oil pan and as far as I could see all was in order so I tapped the shaft a few times with a rubber mallet and it slipped passed the bearing that was holding it. The shaft then slide out the set of the way no issues. I checked the bearings and housing and it looks like no damage. The cam is pretty chewed up and pitted but I was able to knock the stuck lifter down and get it out. I used the good old half a PVC pipe trick to catch it. Looks like all is back on track, a lot of cleanup to do and then start to re-assemble. Will let everyone know how it turns out. Thanks for all the advice.
If your oil filter bypass was not plugged there is a good chance a lot debris went though your rod, main and cam bearings.
You may want to borrow a bore gauge and check the cam bearing wear. That's a good place to start having pressure losses. If you need a standard installed size I can bore gauge a fresh build for you.
That is good news but I agree with Blockman. I'd check the bearings in the bottom end.
Keep us posted.
Pics of the cam and lifter would be good to see.
Good luck
