distributor recommendation 69.
Old Mar 13, 2012 | 06:12 PM
smyth1's Avatar
smyth1
Default distributor recommendation 69.
my original dist is toast.looking at upgrading to hei.noticed some on ebay for under a hundred.
Old Mar 13, 2012 | 07:40 PM
Mark Riles's Avatar
Mark Riles
Just remember that your '69 tach is cable driven from the distributor. If you swap to HEI you'll either need to get one that's been retrofitted with a tach drive cable output or you'll need to switch out your tach for a '75 or up electronic tach. HEI has many benefits and I think you'll like it a lot.
Old Mar 13, 2012 | 08:27 PM
Ironcross's Avatar
Ironcross
The E Bay distributor is cheap and actually a good piece...just make sure the tach drive is on it...and then get a new set of 8MM wires from your local parts store to fit the Vette...A set for a 75 will work
Old Mar 14, 2012 | 02:25 AM
Solid LT1's Avatar
Solid LT1
Get a AAA towing plan for as far as you intend to drive your Vette for when the Chinese electronic module gives up the ghost when your out for a drive.
I would run a Pertronix module inside stock Delco tach drive myself.
Old Mar 14, 2012 | 07:09 AM
Tim H's Avatar
Tim H
Thats all I buy and they have never broke down on me, so just because your against money saving chinese parts doesn't make them junk.
Old Mar 14, 2012 | 07:44 AM
smyth1's Avatar
smyth1
yes,i had a crane module in my original distributor.i tried to rebuild it and cracked the housing trying to press out the bushings.
Old Mar 14, 2012 | 08:21 AM
Iron_dog's Avatar
Iron_dog
Same choice I did, very happy!
Old Mar 14, 2012 | 10:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Rebuild your original tach drive distributor. Add the Pertronix.
Old Mar 14, 2012 | 02:16 PM
smyth1's Avatar
smyth1
original one is broken.cracked the housing trying to press out the bushings.
To distributor recommendation 69.
