Solid motor mounts
Old Mar 14, 2012 | 09:29 PM
RustyBus's Avatar
RustyBus
Default Solid motor mounts
Which solid mounts do I need?
Small block in a 78 corvette
Moroso 62530?
Old Mar 14, 2012 | 10:51 PM
Mark Riles's Avatar
Mark Riles
I have used the Moroso solid mounts many times with great luck. Make sure though that your Corvette is an application. I got burned once by a mislabeled item and they would not fit the frame horns in a Corvette. They were too narrow. So long as they are for sure for a Corvette they will work great. Also when installing, get all six bolts started and the two barrel pin bolts in loosely before you tighten them down. Once all are in or started, tighten the block bolts, then drop the weight of the engine down on the mounts and then tighten the barrel pin bolts.
Old Mar 15, 2012 | 07:14 PM
gkull's Avatar
gkull
62530 - Moroso Solid Motor Mounts
To Solid motor mounts
