AN Fuel Line
Old Mar 15, 2012 | 10:48 AM
knbwag73's Avatar
knbwag73
Default AN Fuel Line
I am getting ready to replace the carb on my 73 small block. Does anyone know how long of a piece of AN -6 fuel line I need from the fuel pump to the carb?
The fuel inlet on the new carb is very close to where the original q-jet inlet is.
Thanks,
Budshark
Old Mar 15, 2012 | 11:17 AM
rogman16's Avatar
rogman16
Thanks,
Budshark
I can measure tonight, but just a rough guess would be 24-30"...
Rogman
Old Mar 15, 2012 | 11:25 AM
MelWff's Avatar
MelWff
I agree, buy 3' and you will have more than enough.
Old Mar 15, 2012 | 11:28 AM
knbwag73's Avatar
knbwag73
Thanks, I was thinking 3 feet as well. Car is not nearby or I would have measured myself.
Budshark
Old Mar 15, 2012 | 11:39 AM
birdsmith's Avatar
birdsmith
If the original metal fuel line is really close as you say to where you need it why replace it with AN-type hose? Modern alco-gas eats these lines from the inside out (ask me how I know this) and can be a real fire hazard in the engine compartment of a Corvette. There's a reason GM used steel lines from pump to carb...
Old Mar 15, 2012 | 12:24 PM
TimAT's Avatar
TimAT
I use a 3/8 steel line and bend as needed, then flare it for -6AN fittings. I'm no fan of the braided lines under the hood- especially on the carb side of the fuel pump
Old Mar 15, 2012 | 04:29 PM
dembo's Avatar
dembo
Looks nicer as well (imho)
Old Mar 15, 2012 | 04:36 PM
rogman16's Avatar
rogman16
That looks very nice....
Rogman
Old Mar 15, 2012 | 05:26 PM
tekvette's Avatar
tekvette
I just pulled all my AN lines and fittings and I'm going stainless hardline as well, mixed in with some teflon lines and fittings. Vapors coming thru rubber were awfull.
dembo, your lines look good and clean. Is it all hard line to the frame?
Old Mar 15, 2012 | 06:41 PM
iokepakai's Avatar
iokepakai
Default Fragola Hose
Used Fragola 8000 push-on hose and AN6 fittings from the pump to carb.
Fairly ez to work with,no fuel smell.I only use ethanol free fuel.....[IMG][/IMG]
Old Mar 15, 2012 | 08:56 PM
scottw's Avatar
scottw
http://www.lbfun.com/warehouse/tech_...uel%20Line.pdf
Great writeup by Lars on a hard fuel line.
Old Mar 17, 2012 | 07:09 AM
dembo's Avatar
dembo
Thanks! It does require patience and a few extra feet of tubing for practice. I used the rigid flaring tool, the cheap summit bending tool, summit nut and collars, 2 swadgelok couplings and a coat hanger.
From frame line supply and return go to the pump with the standard pre formed rubber hoses. From the pump to the carb are two hardlines (you see them both in the pic) as I couldn't snake in a single piece line with the serpentine brackets. The link Scott posted helped me alot.
I still need to fab a bracket to hold it to the compressor to eliminate all vibration
Nick
view on bottom of pump
Old Mar 17, 2012 | 01:13 PM
doctorgene's Avatar
doctorgene
Yes Sir; A good rule of Thumb to use on rubber gas lines. No longer than Six inches (6"). Have a great day. My 1982 has rubber at the tank, & at the in line filter at the frame. Gene
To AN Fuel Line
