Summit Racing Cam Degreeing kit?
Old Mar 15, 2012 | 10:56 AM
ltblue79's Avatar
ltblue79
Default Summit Racing Cam Degreeing kit?
Has anyone used this kit?
http://www.summitracing.com/parts/SUM-G1056/
Or is there a preferred kit out there?
Old Mar 15, 2012 | 11:10 AM
nonracer's Avatar
nonracer
Seems fine, I use a larger diameter wheel but I dont see anything wrong with that kit.
Old Mar 15, 2012 | 11:21 AM
ltblue79's Avatar
ltblue79
i thought that was large. comp's are all 9" while this has an 11"
Old Mar 15, 2012 | 11:35 AM
Vette5.5's Avatar
Vette5.5
Looks pretty much the same, as what I pieced together with a Jomar wheel. I normally degree during a build with the heads off, so made a piston stop out of bar steel stock. Not sure where I got it, but also have an extended lifter, for easier dial gauge readings. Sure you already know this, but depending on the engine, you'll be needing an assortment of offset camshaft keys, bushings, or adjustable gear. Actually, think the larger job "nonracer" mentioned, is the turn handle job, and aren't cheap. If the flexplate is mounted on the rear, usually enough to grab onto.
Old Mar 15, 2012 | 01:20 PM
70BBvert's Avatar
70BBvert
That's the same one I have, works fine. If you've got the heads off buy a solid lifter for your engine as well. Makes setting up the dial indicator on the lifter easier
Jim
Old Mar 15, 2012 | 03:25 PM
nonracer's Avatar
nonracer
I have a Moroso one its 18". I feel the larger wheel is a bit more accurate but degreeing a cam with any wheel is better than not doing it at all.
Old Mar 16, 2012 | 01:33 PM
The Money Pit's Avatar
The Money Pit
I agree the best tool would be the biggest degree wheel you can find.
Myself,..being a cheap skate, just used the flexplate as a "wheel".
Once I found TDC with a piston stop I made from flat steel, I marked the flex plate with a pointer. (Just like using a real degree wheel) Then I looked at the cam card to see where the intake valve should make max lift,....and using my Captain Cruch calculator figured each tooth on my flex plate equalled 2.14 degrees. Count the teeth from the TDC mark, and mark that spot on the flex plate. Then I rotated the crank to move my new mark to the pointer while watching the number one intake lifter in the block to see it move.
Then I marked the flex plate a few teeth left and right of my "new mark", and moved the flex plate to one of those marks. Measured with a mic how far the lifter stuck out of the block. Move the flex plate to the opposite mark, and rechecked the lifter height. Sort of like finding TDC with a piston stop. The measurements matched.
I know it is crude, and am not saying this is "right". But I am fairly confident the cam is installed about as close as the cam card called for.
And definately better than just slapping the cam in without checking.
To Summit Racing Cam Degreeing kit?
