New alternator plug, cables diff in size.
Old Mar 17, 2012 | 04:01 AM
454LS6's Avatar
454LS6
Default New alternator plug, cables diff in size.
So i ordered a new alternator plug, got it just yesterday and was about weld the hot cable with the old one, but i noticed the cable in the plug was a little bit smaller then the old one. What will happen, and what do i risk when welding these ones? They dont differ very very much in size, but asking never hurts. New to this.
Probably should'v taken off the shoe on the old cable to make the thickness of the copper wires more clear for you.
Old Mar 17, 2012 | 04:12 AM
Slonneck's Avatar
Slonneck
Navigator
The size of the wire matters a lot less than the rating. Can you read any numbers/letters on the new wire? This should tell you what that wire is rated for, as long as your alternator doesn't exceed that, you should be okay.
Old Mar 17, 2012 | 06:56 AM
454LS6's Avatar
454LS6
I will take a look next time i am in the garage. Dont think there are any numbers or letters on there though.
Thanks!
Old Mar 17, 2012 | 07:25 AM
noonie's Avatar
noonie
It doesn't matter.
The red "bat" wire is the using all the amperage.
Old Mar 17, 2012 | 08:00 AM
454LS6's Avatar
454LS6
Originally Posted by noonie
It doesn't matter.
Right, thanks man.
To New alternator plug, cables diff in size.
